E-Class (W213) 2016 - 2023
vehicle is in Motion Problem
Old Apr 20, 2023 | 05:24 PM
mahmoodfarook's Avatar
E300
Exclamation vehicle is in Motion Problem
Dear All
E300
W213 Model 2017
i'm facing a problem that Even the car is Stopped it shows vehicle is in Motion.
i did a reset to my car and anything require a keyboard is Disabled as the system see the Car is in motion even while it's parked and engine off and i can't do any of the following :-
- Activate my Apple CarPlay
- Add any Password
- write any Destination in the Navigation Map.
- connect the car to the internet.
Did any one faced this problem before ?
Old Apr 20, 2023 | 06:22 PM
ua549's Avatar
Did you reboot the entertainment system by holding the off button down for at least 10 seconds?
Old Apr 20, 2023 | 06:34 PM
E300
Yes i did
and since then i faced the problem
Old May 27, 2024 | 02:24 PM
joshrt's Avatar
W213 2019
Same issue
Originally Posted by mahmoodfarook
Yes i did
hey guys i have the same problem
were you able to fix it ?
Old May 27, 2024 | 02:38 PM
Pierregirard's Avatar
Mercedes-Benz Vision EQS
The issue might be due to a bad wheel speed sensor or a problem with the vehicle's gyroscope sensors if it has them. These sensors help the car know if it's moving. You should get these sensors checked for any faults or errors.
Old May 27, 2024 | 03:11 PM
joshrt's Avatar
W213 2019
i did the same reboot mentionned above and the problem appeared so i don t think it s a sensor
