E-Class (W213) 2016 - 2023
My new vehicle has no TPMS in wheels
Old Jul 31, 2023 | 10:11 PM
Ryan’s's Avatar
2023 E450 4matic sedan
I live in Ontario, Canada and own a 2023 e450 4matic airsuspension. 18 amg 5 spoke.
I happened to have a chance to take a tire out of rim and found out no sensor in wheels
How the hell it can tell tire pressure within range in MB me app or cluster? Ofc I don’t see exact numbers in psi. It just says within range.
Wtf is going on here? Any other Canadian E450 owners’?
Old Aug 1, 2023 | 12:12 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
The are two different methods for monitoring tire pressure, physical pressure/temperature sensors that you refer and using the ABS system. The latter "counts" pulse rate differences indicating a change in tire rolling diameter as pressure drops.
The ABS system works, just not as sensitive as sensors. And it doesn't pick up pressure changes on all four tires asthe weather changes.
Old Aug 1, 2023 | 11:02 AM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Sensors are not standard in Canada. I think they are standard in the US, but I could be wrong there.
I've a 2020 E450 here in Vancouver, and it doesn't have TPMS in it. Pretty shameful considering every single junkbox rental I've had for the last couple of years has TPMS.
I'm not sure what the exact tire pressure monitoring method is without the sensors (something to do with monitored wheel spin perhaps?), but it has worked for me once.
Old Aug 1, 2023 | 11:38 AM
lkfoster's Avatar
The ABS-based system does work. It got me back from Yosemite to Phoenix once. Had to stop every 30 miles to reinflate a tire before I could find a replacement but I couldn't have made it without the alerts.
And my Audi uses the same system for what it's worth.
Old Aug 1, 2023 | 11:47 AM
superswiss's Avatar
2019 C63CS
When it comes to TPMS, there are two distinct systems. With pressure sensors referred to as direct TPMS and w/o pressure sensors referred to as indirect TPMS. The latter is what you have. It uses the wheel speed sensors to measure tire rotation differences and Eigenfrequencies in the wheel assemblies and then performs digital signal processing to determine loss of pressure. These parameters are directly related to tire pressure. It requires that you reset the system diligently whenever you adjust the tire pressure or make changes to the wheels as it must learn the base parameters to work correctly.
The easiest way to tell the two apart is if your valves have rubber stems then you have indirect TPMS and if they have metal stems then you have direct TPMS.
For a bit more explanation on the different systems, easy digestiable information can be found on Wikipedia:
https://en.wikipedia.org/wiki/Tire-p...itoring_system
Indirect TPMS[edit]
Indirect TPMS (iTPMS) systems do not use physical pressure sensors; they measure air pressures using software-based systems, which by evaluating and combining existing sensor signals such as wheel speeds, accelerometers, and driveline data to estimate and monitor the tire pressure without physical pressure sensors in the wheels. First-generation iTPMS systems are based on the principle that under-inflated tires have a slightly smaller diameter (and hence higher angular velocity) than a correctly inflated one. These differences are measurable through the wheel speed sensors of ABS/ESC systems. Second generation iTPMS can also detect simultaneous under-inflation in up to all four tires using spectrum analysis of individual wheels, which can be realized in software using advanced signal processing techniques.
iTPMS systems are sometimes referred to by other names, such as Ford's ‘Deflation Detection System (DDS)’[7] or Honda's ‘Deflation Warning System (DWS)’.[8]
iTPMS cannot measure or display absolute pressure values; they are relative by nature and have to be reset by the driver once the tires are checked and all pressures adjusted correctly. The reset is normally done either by a physical button or in a menu of the on-board computer. iTPMS are, compared to dTPMS, more sensitive to the influences of different tires and external influences like road surfaces and driving speed or style. The reset procedure,[9] followed by an automatic learning phase of typically 20 to 60 minutes of driving under which the iTPMS learns and stores the reference parameters before it becomes fully active, cancels out many, but not all of these. As iTPMS do not involve any additional hardware, spare parts, electronic/toxic waste, or service (beyond the regular reset), they are regarded as easy to handle and customer friendly.[10] As mentioned however, the sensors must be reset every time changes are done to the tire setup, and some consumers do not wish to have this added responsibility.[11]
Since factory installation of TPMS became mandatory in November 2014 for all new passenger vehicles in the EU, various iTPMS have been type-approved according to UN Regulation R64. Examples for this are most of the VW group models, but also numerous Honda, Volvo, Opel, Ford, Mazda, PSA, FIAT and Renault models. iTPMS are quickly gaining market shares in the EU and are expected to become the dominating TPMS technology in the near future.
iTPMS are regarded as less accurate by some due to their nature—given that simple ambient temperature variations can lead to pressure variations of the same magnitude as the legal detection thresholds— but many vehicle manufacturers and customers value the ease of use.[[i]citation n
Old Aug 1, 2023 | 06:45 PM
norken's Avatar
2017 e300
When I purchased my w213 2017 TPMS ( to display psi value on screen) is optional $720 cad. I guess it maybe still an optional or a package you need to pay for.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
