Question on Shock Absorbers
Would appreciate a little help from all the wise ones out there please. My 2018 E300 is in for the B service and the dealer is stating that my rear shock absorbers are leaking and recommends replacement. I am the sole owner of this car from 3 miles on it and it currently has 59,432 miles on it. I have never had a vehicle that needs shock absorbers replaced under 90K miles because they are leaking??? Does this sound right to you all? Has anyone else experienced this? The dealer wants $1,846 to replace the rear shock absorbers and I am sure they will find a way to NOT cover it under my extended warranty. Seems like a price raping.to me. Any feedback is greatly appreciated. Thank you so much for your help!!
So what gives?
I now think my front shocks will need to be replaced.
However, according to my extended warranty with MB, they are covered.
Hopes this helps.
OEM E53 rear shock, adjustable
That and I don't see any leakage and I've had my share old leaking shocks. There skills be obvious wet signs which I don't see.
In the latter you will get bouncing, anything more than just upward rebound movement indicates wear of the Internal bore and/or the piston rings. To test for this push down on a corner of the car, if it comes up only slowly the shock should be ok. If the corner comes up quickly and back down again the oil is by-passing the piston valves. You can't see any external signs of that.
Adjustable shocks have external valve bodies but those didn't look like they had that.
