E-Class (W213) 2016 - 2023
Best Full Screen Dash
Old Feb 15, 2024 | 03:49 PM
soupi's Avatar
2017 E300
Hi Everyone, can someone lead me to link that has the best full screen replacement for the dash for a 2017 e300. I wanted to update mine and see so many from china and didnt want to add one that will bring dash lights or errors. THank you.
Old Feb 16, 2024 | 01:32 PM
Waw642's Avatar
2017 E300
Installing a used instrument cluster is not as simple as it may appear. If the cluster is used and tied to another vehicle, you will need to reset the eeprom via a "virginization" process. The instrument cluster is an IC213 and you will likely need to connect to it on the bench with an OBD passthrough device to properly communicate and perform this process. If you are not technically inclined, I do not recommend pursuing this, as it is possible to mess up a setting and set your odometer to 999,999 mi, which can't be undone.
Old Feb 16, 2024 | 01:41 PM
soupi's Avatar
2017 E300
Got it. Where can I buy a new replacement full screen. Then I'll take it somewhere to get programmed
