E-Class (W213) 2016 - 2023
Sunroof drain hoses
Old Feb 19, 2024 | 10:41 PM
BoMB's Avatar
2018 E300 4Matic Sport
Sunroof drain hoses
Hello all, I am sure many of you know about this problem. A friend told me that the sunroof drain hoses are clogged. Why? He's seen it before, and as a result I am finding water on the floor of the passenger side floor (and a bit on the driver's side door). I called the local dealer, he agreed, and he said it's a common problem, so without looking at it, he's pretty sure it's clogged.
Question for everyone...should this fix be covered by warranty? Thanks in advance.
Old Feb 20, 2024 | 07:12 AM
ua549's Avatar
I would not expect any kind of cleaning to be covered by warranty.
Old Feb 20, 2024 | 09:05 AM
Mago 51's Avatar
Merc. S-213 220d / Jag XJ-40 / Jag X-Type Estate
Interesting topic indeed.
No probs so far but would be good to know where those drains are. Any scheme avail?
Had this issue in my former Audi and it is better to prevent with some pre-cleaning.
Cheers,
Old Feb 20, 2024 | 09:09 AM
BoMB's Avatar
Interesting. I guess I didn't see it as simply cleaning, as much as I see they are not designed to clog and cause water to leak into the car. Yes, they do, and it's circumstantial, but I wasn't sure about this. Thanks.
Old Feb 20, 2024 | 01:58 PM
BoMB's Avatar
Called the dealer...Price quote is $687! One hour to diagnose and then 2 hours to remove the fender liners and clear any blockage/obstruction. How lovely!
Old Feb 20, 2024 | 02:17 PM
ua549's Avatar
A thin snake may work just as well.
Old Feb 20, 2024 | 02:24 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
.. There are plenty of video in YouTube for all the Benz classes. ALL use the same system
Take some time, do it at home, and take your significant other for a nice dinner.
NOTE: do NOT use compressed air, it can disconnect the drain internally if heavily clogged and $687 will be the tip for the mechanic.
Old Feb 20, 2024 | 04:05 PM
SpeedracerZ's Avatar
2018 E43
Haven't run into this yet in in e43 but in previous cars I've ran a thick string trimmer line down each line to clean them out. Usually there is a drain at each corner of the sunroof frame you can access from above.
Old Feb 20, 2024 | 04:33 PM
JCM_MB's Avatar
You can run the string both ways, from the top or from below.
Old Feb 23, 2024 | 07:54 AM
The G Man's Avatar
2019 E300
The rattles they caused will be free of charge.
Old Feb 23, 2024 | 02:19 PM
Cao Black's Avatar
2015 ML350+2025 E350
Has anyone ever tried computer / keyboard compressed air? Or even a compressor set to a very low pressure.
Old Feb 24, 2024 | 12:00 PM
The_Judge's Avatar
2018 E400 Coupe
How do you get a piece of string down the drain tube? Isn't it rather narrow?
Old Feb 24, 2024 | 12:20 PM
JCM_MB's Avatar
How much wider you need it to be? Perhaps you are looking at the wrong place?
Did you watch the videos?
I can fit a narrow pencil through it
Old Feb 24, 2024 | 12:33 PM
The_Judge's Avatar
2018 E400 Coupe
Yeah, i did, and neither of them include anything about running a string down the narrow, 4- to 5-foot long plastic tube that runs from the sunroof through the front roof support and out the bottom of the car, where it drains. I can't image any way to get long piece of limp string down that tube from its top and out its bottom. Of course, it would be a very useful tool if you can do it, so please explain how. Thanks. .
Old Feb 24, 2024 | 01:05 PM
JCM_MB's Avatar
Old Feb 24, 2024 | 03:06 PM
The_Judge's Avatar
2018 E400 Coupe
Thanks, very helpful!
However, what is used in the video is not “string“ is as I understand the term (i.e., made of cotton or jute, etc., thin and very limp so it can be tied in knots).
Rather, it’s a long, thin piece of flexible plastic such as that used in Weed Eaters and other trimmers, obviously stiff enough to push down the long drain tube. Available on Amazon: http://tinyurl.com/28fu49lp
Doug Collins
Hermosa Beach, CA
Old Feb 24, 2024 | 03:10 PM
JCM_MB's Avatar
https://www.homedepot.com/b/Outdoors...s/N-5yc1vZbx8i
That is the vocabulary used to sell them
Old Feb 24, 2024 | 04:47 PM
BoMB's Avatar
I am lucky I can start my car...but I am going to give this a shot. Not worth close to $700 and then feel like I got screwed, LOL.
Old Feb 25, 2024 | 10:57 AM
MNIAW's Avatar
2017 M-B E400 4Matic Wagon AMG-Line
FWIW, VW and Audi owners filed a class action lawsuit and won.
For this very same problem.
VW Website
