E-Class (W213) 2016 - 2023
touch pad retrofit?
Old Mar 2, 2024 | 04:26 PM
Belal's Avatar
2014 E550 4MATIC / 2019 E53 4MATIC
touch pad retrofit?
Hi all I have a 2019 E53, I feel like the touch pad is outdated and I have seen the newer ones and I like them. Have any of you tried to retro fit it I have seen some on Ali baba that says plug and play and I want to try them but I do not know if they work, has anyone done it, does it need any type of tuning or is it plug and play,
also any recommendation on dashcams i have seen the integrated ones and I do like them but i need more opinions about it
here is an example.
this is what Im thinking of buying
this is what I am talking about
Old Mar 2, 2024 | 08:52 PM
kingscorpian27's Avatar
MB W213 E300 4MATIC Luxury Model
here is an example.
I have the 4K dash cam front and rear 1080 see attached of front only. Works great and fantastic videos. Plug and play, installs in 10 minutes. I’m actually going to get OEM touchpad once I upgrade to MBUX. If you have touch screen then the touchpad is worth it, if you don’t then may not work as well not having the dial.
4K DashCam
Old Mar 4, 2024 | 04:47 PM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
So I agree that the touch pad config in the center console is really cumbersome. That said without a touchscreen, I'd need a solution has some sort of a touch pad in the center console. The only other fix would be swapping out my non touch screen to a touch screen and then get rid of the touch pads on the center console but unless there is truly a plug and play solution that'll accomplish both issues, my sense is that it probably isn't worth the bother for me.
Old Apr 11, 2024 | 12:58 PM
Belal's Avatar
Originally Posted by City Rat
. That said without a touchscreen, I'd need a solution has some sort of a touch pad in the center console. .......
the one I put in the picture has a touch pad center console, my question is is it plug and play, they did not respond to me, because if it is. It looks good and OEM and it would be better.
Old Apr 11, 2024 | 02:41 PM
Cao Black's Avatar
2015 ML350+2025 E350
Regarding the integrated dashcam, is your sample Fitcamx?
They have a web site...Fitcamx.com, and they are sold on Amazon...
Amazon Amazon
, where you can read (real???) customer reviews.
Old Apr 11, 2024 | 03:25 PM
Belal's Avatar
They have a web site...Fitcamx.com, and they are sold on Amazon...https://www.amazon.com/Suitable-Merc...=sr_1_3?sr=8-3, where you can read (real???) customer reviews.
fit cam is literally buying these from alibaba and rebranding them. I would rather buy directly from source
what I mainly care about is the touch pad if it works or not
Old Apr 11, 2024 | 04:12 PM
BoMB's Avatar
2018 E300 4Matic Sport
I don't know a thing about the dash-cam aspect of this -- but for the touch-pad, I like the replacement one far better than the standard one that comes with the E-class. Thanks for posting these.
Old Apr 11, 2024 | 04:19 PM
Belal's Avatar
is it plug and play? Some people said yes others said you need a tune, and some people said it works normal except for Android auto it does not. What's your perspective and where did you buy it from?
Old Apr 11, 2024 | 06:09 PM
YYC53's Avatar
2020 E53 AMG
For what it's worth, I am experimenting with a new Carlinkit Tbox. Without the rotary dial you wouldn't be able to access some functions. Not something most will worry about but if you're carplay/android autoing it the rotary is useful and would be a problem if no touchscreen.
Old Apr 11, 2024 | 09:58 PM
BoMB's Avatar
I didn't buy it...I was just saying I like it, meaning I like the look! If it was plug and play, guaranteed to work, didn't need to be re-programmed or tuned, I'd do it. However, I've heard that "tuning" voids your warranty, so, no, not for me, LOL.
Old Apr 12, 2024 | 12:43 PM
Abzynthe's Avatar
A238 E53 & V167 GLE53
The new touch pad looks way better. Having the cabriolet, we have the touchscreen, touchpad and idrive wheel all to do the same thing!
Old Jul 19, 2024 | 03:57 PM
michael640D's Avatar
2018 E63S,2016 C63 S Edition 1 Coupe(gone), 2011 640D M Sports Coupe, 2015 435i M Sports Coupe
i have tried two touchpads from diffrent suppliers to fit to my 2018 W213 E63S the pad worked well in both normal screen and Apple carPlay the only problem with of the. was when the touchpad was plug in to car it made the mode buttons either side function strangle ie the park/camera button would not work at all, the M button would turn on when one press of the start button was pressed this should be off until pressed when engine is running. The exshaust button and auto stop button would come on when engine started the surspension light would only ever show one light ie sports surspension but would not light up the second light ie sports plus surspension although it changed the surspension setting on screen one light would alway be on so end up sending it back. So would like to know if anyone has successfully managed to change the orginal wheel and touchpad to new type and everything has worked correctly on a 2018 to 2021 E63S let me know where you bought it from👍 because I hate the orginal wheel and touchpad because on right had drive cars you can’t see the set of buttons to the left of it which is the manual, traction and surspension buttons which is a pain in the *** when you want to change any settings.
Old Jul 19, 2024 | 06:12 PM
City Rat's Avatar
Veteran: Army
The issues that you raise and are experiencing with the retro fit of the touchpad also speak to a larger issue, i.e., has anyone found an upgrade to the head unit, which I suspect will also impact the controls now. For me I 100% agree with you on the redundancy of the dials and touchpads. I have a 2019 E450 biturbo and my brother is leasing a 2024 E 300 which does away with redundant control surfaces. Second, one of the first things that I upgrade in any car is the head unit. Usually, it is to get an updated user interface, as we are discussing and equally important to me to give me more control over the sound, specifically, quality of high end, mids and bass. In this car it means adding a subwoofer as I have no qualms with the tweeters and mids but hate that my bass is sound engineered in. Not looking to add some non-sense gigantic sub box filled with a crap product used by kids who want to have annoying loud parties. There are some nice, low profile subs that I've used as direct replacements for MBZ factory subs that fit in factory enclosures and work like a charm that I'd like to use. All of that said, I fear that the sound system is now so integrated into other car functions that trying to upgrade or replace it will encounter all of the same issues that you are having by trying to replace just the touchpads.
So to add on to your request:
1- has anyone successfully replaced the multiple interface touchpads?
2- has anyone successfully replaced the head unit?
3- (here this is me throwing my hands up surrendering) has anyone been able to successfully wire in a subwoofer to either the existing head unit or added the sub via wiring in a small auxillary amp and sub to the existing MBZ factory system in 2019 -2024 E class vehicles.
Old Oct 6, 2024 | 11:54 AM
Murmuring2860's Avatar
MB E 63 S 2018 W213
I encountered the same problem as you (I have exactly the same model of car, E63S 2018) with AliExpress touchpads, and with OEM buttons. I tested with an original mercedes from a GLC, the buttons all work without problem, except for the park/camera button (I don't know why...), but the touchpad does not work at all.
I found a OEM touchpad in England from an E53 2023, I'll try to find the cable with it and I'll come back to you if it works “plug and play”. I also think that the cable is important, as ours has more connectors (for the selection wheel and for the original touchpad) than the later models with the new touchpad.
Old Oct 6, 2024 | 01:16 PM
okay will instead to hear if it worked or not I have given up for the moment as was talking by email to one of the sellers on Aliexpress and admitted that the new type touchpad doesn’t work on AMG models but he was going to try and do some work to get them working and let me know so I can test it out to see if it works.
so keep me informed if you have any luck in getting it to work 👍
Old Nov 22, 2024 | 01:42 PM
MB E 63 S 2018 W213
Hello,
Following the purchase of my touchpad for the 2023 E53 AMG, I also acquired the associated Mercedes cable. The side buttons work without any issues, the haptic feedback and click function properly, and I can see the position of my fingers via Xentry when running a diagnostic. However, I am unable to control my screen with it.
Since I have the necessary software for reprogramming, I will try to make it work this way.
Looking forward to exchanging ideas with anyone who has strong coding skills!
Old Nov 22, 2024 | 03:28 PM
Abzynthe's Avatar
Hello,
What do you use to code? I’ve tried searching but couldnt find anything.
I’ve done all sorts of coding with my BMW and would love to be able to do the same with the Mercedes.
Old Nov 24, 2024 | 09:16 AM
MB E 63 S 2018 W213
I'm using DTS Monaco with OpenPort 2.0 (from AliExpress) or VCX SE (from AliExpress too).
Old Dec 4, 2024 | 08:34 AM
Abzynthe's Avatar
Thanks for that. I had a look and im confused haha. Could you point me in the right direction? It looks a bit more complicated than the E-Sys for BMWs.
Old Jan 20, 2025 | 02:12 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Did you manage to get it to work?
