E-Class (W213) 2016 - 2023
2017 Mercedes E300, rear door still opening after alarmed! HELP ☹️
Old Nov 5, 2024 | 12:53 PM
Roman living's Avatar
Exclamation 2017 Mercedes E300, rear door still opening after alarmed! HELP ☹️
I have a 2017 Mercedes E300 and I discovered that I can open one of the rear doors after alarming it and my key fob is nowhere near it this only happens to one of the doors the right rear one and the alarm go's off, again only on the right rear door and the door plunger is down and working.
I've checked on my OBD scanner under chassis- doors and actuator and did a live test no codes and everything is fine.
I've read somewhere that it could be a software glitch but nothing is coming up on my 5k Autel OBD scanner!
Also when I do arm it the door lock plunger does go down everything mechanically is working correctly.
* It's very random but here's the funny thing on the key fob if I arm it twice which you shouldn't have to the doors stay locked!
Has anyone had this issue thanks in advance! 🙂
