E-Class (W213) 2016 - 2023
Wheel offset
Old Mar 4, 2025 | 10:03 AM
voodoo3dfx's Avatar
mercedes E 200 d
Wheel offset
I want to change my wheels, from 17 to 19. Have read that usually the offset for a 19" wheel is ET43. Have found an offer for some wheels that are 19 inch, 8j, but ET33. Will they mount fine? is the same as mounting a 10mm spacers on a ET43?
(i am going to mount same tyres front and rear).
Thanks a lot to anyone could help
Old Mar 4, 2025 | 10:19 AM
cydewaz's Avatar
voodoo, yes you will be fine. Here's my real-world example: my e450 came with 19x8et43. I have installed 19x8.5et45 plus 12mm spacer, thus bringing the total offset to et33.
yes, that is the same as mounting a 10mm spacer on an et43
Old Mar 4, 2025 | 11:07 AM
voodoo3dfx's Avatar
mercedes E 200 d
Thanks a lot for the answer :-) (The same set will work on front and rear wheels, right?)
Old Mar 4, 2025 | 01:40 PM
cydewaz's Avatar
yes. unless you want to go with a staggered fitment. the rear can handle a much different setup. I kept the setup square since I have the 4matic and for simplicity.
Old Mar 4, 2025 | 03:03 PM
W205C43PFL's Avatar
Plus ability to rotate all four tires?
Old Mar 4, 2025 | 04:52 PM
voodoo3dfx's Avatar
mercedes E 200 d
Thank you very much!!!
Old Mar 4, 2025 | 05:03 PM
W205C43PFL's Avatar
Hope you find the set you are looking for OP : )
Old Mar 21, 2025 | 08:28 PM
s213ryan's Avatar
2018 E400 Wagon
Do you have pictures of how they fit on your car? I'm looking for wheels for my S213 and trying to get some idea of the offset and width that I should be running
Old Mar 21, 2025 | 11:33 PM
Cao Black's Avatar
2015 ML350+2025 E350
https://mbworld.org/forums/market/890997
Any interest? I'm ready to deal.
