E-Class (W213) 2016 - 2023
2019 E class rear brake replacement
Old Mar 22, 2025 | 02:13 PM
1guitar's Avatar
E300-4matic
I wish need to replace my rear pads on my W213 pretty soon. A few quick questions for those folks that have any answers, which will be very much appreciated. My understanding is the with the ignition on, the parking brake needs to be released, the rear brake fitting position needs to be selected and the ignition needs to be left in the “on” position until the job is done at which time you can select the fitting position and then pump the brakes after which you can engage the parking brake. Also, my car is 7 years old, do you think the “floating pins” need to be cleaned and regreased. Again thanks for all of your replies.
Old Mar 22, 2025 | 06:31 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Do not forget to replace the sensors as well.
Old Mar 31, 2025 | 01:11 PM
groker's Avatar
i think the floating pin needs to be greased every a couple of years.
Old Apr 11, 2025 | 10:30 AM
W205C43PFL's Avatar
Yes it is recommended to clean the pins.
