E-Class (W213) 2016 - 2023
2017 ML E300 Sensor Issues
Old Aug 16, 2025 | 01:38 PM
neapolitan's Avatar
Mercedes ML320 2001
I have limited knowledge of cars so I need your expertise. I have 2 alerts on my dashboard that indicates the below:
1. Wheel Sensor Missing - Front Right
2. Check Brake Wear - The brakes were recently fixed by a mechanic but doesn't look like he reset the sensors. A second mechanic checked today and said the brakes are new but I need a sensor.
I found this brake sensor on Amazon and need some advice if this is the correct one:
Amazon.com: A-Premium Front or Rear Brake Pad Wear Sensor Compatible with Mercedes-Benz C300 2015-2017, C350e 2016-2017, C400 2015, E300 2017, E43 AMG 2017, GLC300, GLC43 AMG, CLA250, CLA45 AMG, GLA250, GLA45 AMG : Automotive Amazon.com: A-Premium Front or Rear Brake Pad Wear Sensor Compatible with Mercedes-Benz C300 2015-2017, C350e 2016-2017, C400 2015, E300 2017, E43 AMG 2017, GLC300, GLC43 AMG, CLA250, CLA45 AMG, GLA250, GLA45 AMG : Automotive
Also, I have no idea what sensor needs to be installed for the tire pressure. Can someone recommend the correct parts
so I can order online?
Old Aug 16, 2025 | 05:56 PM
The G Man's Avatar
2019 E300
might want to post this on the ML forum.
Old Aug 17, 2025 | 10:08 AM
CarFan1's Avatar
Porsche Cayman S, Mercedes W213, Nissan Titan, BMW X5, Chevrolet Suburban
The parts list he posted indicate that he isn't looking at an ML class. Most likely that is a typo.
Old Aug 17, 2025 | 11:35 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
Call the parts dept of any MB dealership, give them your VIN and ask for part number. Then search the Internet or that part. I would also be going back to the mechanic and asking about the brake sensor. Sounds like he forgot something and should either make it right or give you some money back. Not likely getting money back, but that wouldn't stop me from complaining.
Old Aug 17, 2025 | 11:45 AM
MNIAW's Avatar
2017 M-B E400 4Matic Wagon AMG-Line
Wheel sensors are your tire pressure monitoring system sensors. The batteries give out in them. Despite what some people will tell you, you do not need OEM sensors and they do not need to be programmed for your car. Any reputable tire shop will be able to provide and install them for you. In the US, the sensors can be found for as inexpensive as $15. The tire shop will have to remove the tires to put the new sensors in. If one of the sensors has died, chances are the other 3 are not far behind. Replace all 4.
Old Aug 17, 2025 | 03:49 PM
neapolitan's Avatar
Mercedes ML320 2001
Thanks. I appreciate your answer. Let me try calling MB Dealership first and see what they say, and then I'll look for the parts online. Appreciate all the responses here. Thanks!
Old Aug 17, 2025 | 03:54 PM
neapolitan's Avatar
Mercedes ML320 2001
And yes, it was a typo. I meant MB.
