Door handle issues
When I touch the little notch on the handle it repeatedly locks or unlocks the car rather than extending the handles. I have to fumble with them several times before I can get them to extend.
The manual says you can touch the handle anywhere in the center zone and it should extend but it seems like the only thing that makes them extend is a swipe, where the center sensor gets touched first and then the notch gets touched at the end of the gesture.
It’s almost like the sensors aren’t sensitive enough or the documentation in the owners manual is completely wrong.
Does anyone else have this same issue?
For me, I think it's just a software issue where the car does not expect the behavior and doesn't react properly. It's rare and not a huge deal, but can be annoying when it does happen. On even less occasions, it will retract as I grab the handle to open. It hasn't cought my hand, but it feels like it would have if I didn't pull away quickly. This may be my fault as I've really only had this happen when I use one or two fingers and am not centered on the handle. I've tried to replicate it but it never does it when I try.
I had another glitch for the first time today. Pulled into the driveway and shut the car off to vacuum the front mats before moving into the garage. Started the car, put in drive and it wouldn’t move. The tach showed it was running at idle but an alert popped up saying “speed severely restricted”. I shut it off, restarted and same thing. After the third time I was able to drive it into the garage but wasn’t sure if it was sluggish or not.
