Best all-season tires for '25 AMG E53
Translating to an extra 8 revs of longer travel every mile (735 vs 743)........which translates to an additional 60 feet traveled by the front tire, vis-a-vis the rear tire, every mile.
That additional 60 feet of travel by the front tires, are happening every single mile, and is being absorbed by the drivetrain somewhere. My question is, what not just do the near perfect match by adopting a 255/295 combo, OR a 265/305 combo. I get the logic of the 305 potentially causing interference, which would mean the best combo would be the 255/295 combo.
Either way, a set with matched diameters, will not have this problem, and is available, and I have no idea why they did not just do it the right way, and decided to mess around with mismatched diameters. As stated, a 255/295 or a 265/305 are very close matches.
Others tyres in 265 and 295 may not respect MB sizes
i do enjoy both in France.
although the NY resident didn’t respond to the need to drive in the winter - a critical consideration, the choice of tires is 1) summer, 2) winter, 3) all weather and 4) all-season. As tires are designed around either OEM specifications as in the MO designated tires or to serial, tire-line designations. As example, summer and winter tires are designed with a narrow temperature range in mind and conditions those temperature ranges and road conditions they will encounter. The break-point between summer and winter is approximately 7 degrees C or about 45 degrees F. So, then all-weather and all-seasons tires are a compromise between summer and winter both in terms of temperature compatibility and performance expected in that range - not intended for extreme on either end, cold or hot. The odd duck in this, using Michelin as example is the relatively new all-weather CrossClimate3 which is a world wide tire as the rest of the universe doesn’t broadly accept the notion of all-season … yet.
for the originator of the string, I’d still opt for a winter/summer set of tires on dedicated wheels but if they want to economize (with an E53) on a single set then I’d offer that going to the Michelin CrossClimate in sizes near what the E450 uses with the 20” staggered sizes offer (OE= 255/40 & 285/35) with dimensionally acceptable 255/40 & 275/35 - which is 1.5% smaller on the rear than OE.
let the controversy begin.
Let's say that it is 45 degrees now, but will go to 55 degrees in the afternoon. But tomorrow is 45 degrees going down to 35 degrees. I'd rather be on all seasons or all weather tires than on winters or summers.
I've seen studies showing that driving on summer tires below 45 degrees is a bad idea. But I've never seen data on winter tires at 55 degrees. Is driving on winter tires at 55 degrees crazy stupid, or is it just going to extend stopping distances a bit? We can probably agree that driving on summer tires at 35 degrees is not for the sane of mind.
For seasons where the temperature is above 50 degrees every day, summers are the best tire. For seasons where the temperature is below 35 degrees everyday, winter tires are the best option. In the NY area we just had days below 45 degrees in May 2025 and we have had warm days in November.
I have no problem recommending CrossClimate 2's year-round. Michelin does not sell CrossClimate 3's in the US as far as I know. Michelin thinks US drivers prefer the longer lasting CrossClimate 2's to a better performing but faster wearing CrossClimate 3.
High Performance All Seasons, like the Michelin Pilot Sport A/S are getting close to summer tires in performance, so there is less of a compromise than there was 20 years ago. Likewise CrossClimates perform decently in the summer and the winter.
It's not even as simple as all season versus winter and summer or going all weather. There are full winter tires, such as the X-ICE that are best on snow and ice, then there are performance winter tires like the Pilot Alpin which do well in snow but act more like an all-season for handling, then we have all seasons, performance all seasons, grand touring all season, long lasting all seasons, performance summer tires, ultra high performance summer tires, and track tires. Each category has some characteristics that are better and some characteristics that are worse than other categories.
When you are suggesting winter tires, are you suggesting snow and ice tires or performance winter tires? Would you say that the CrossClimate 2's with the 3 peak mountain snowflake symbol counts as a winter tire?
When suggesting summer tires, are you suggesting something like a grand touring summer tire with sound deadening, a high performance summer or an ultra high performance summer tire?
I'll agree with you that summer tires are best in hot weather and winter tires are best in cold weather. I'd also say that in the NY area, from March through May and from September through November we don't always know if next week will be warm or cool.
I had CrossClimate2's on my Volvo V90 Ocean Race and they were a great all season tire. There was a low frequency hum above 55mph due to the tread design but not offensive. The Volvo dealership recommended them and said it was their most popular replacement tire.
- Studdable winter tire
- Studless snow and ice tire
- Performance winter tire
- All-weather tire (maximum wear ratings)
- All-season tire (maximum wear ratings)
- High performance and ultra-high performance all-season tire
- Summer tires (high performance, ultra-high performance, max performance)
Most people will do fine with all season or all-weather tires year-round. I recommend CrossClimates to friends. CrossClimate 2's are not yet available on the 20" wheels for the E53, but are available in the size of the 19" winter wheel and tie package. For folks who want to skew towards summer performance or winter performance here are some combinations to consider:
- CrossClimates for winter, fall and spring switching to summer tires in the summer. (Gives up some warm weather performance in the fall and spring.) I do this on my X5 because it came with summer tires. The incremental improvement of the summer tires for an SUV is barely worth the switch, but the summer tires are quieter.
- CrossClimates for winter and high-performance all-season tires for summer, spring and fall. (Gives up some summer performance for more performance in fall and spring.)
- Leaning more into winter performance, Pilot Alpins in the winter and high-performance all-season tires for summer, spring and fall. (Adds more winter capability in snow and ice)
- Leaning even more into winter, X-ICE in the winter and high-performance all-season tires for summer, spring and fall. (Adds more snow and ice capability at the expense of dry handling and stopping)
- High-Performance all-season tires that work in snow or CrossClimates (all weather) year-round. (Gives up optimal snow, ice and summer handling, but as the temperature is going from cold to warm or warm to cold, they will perform well.)
- For people prioritizing longer wear over performance, CrossClimates or a long wearing all-season tire is better than a faster wearing high-performance all-season tire.
I checked recently with my local parts department. They no longer have a 19" winter tire package listed for the E53. At the moment, the winter options for the E53 seem to be 20" wheels with Pilot Alpins or 20" wheels with Pilot Sport All Seasons.
It's not as simple as "skip all-seasons and use winter and summer tires instead." One of my least favorite combinations is winter tire and summer tire. Winter tires lack feel and take too long to stop in the warmer weather. Switching to summer tires too early is dangerous due to lack of traction when it gets cold. Timing the switch involves both luck and planning. My preferred combination would have an all-weather or an all-season tire somewhere in the mix. If I was living somewhere that was consistently warmer or consistently colder, my preference would skew accordingly.
