Digital Extra colored codes clarification/Audio Streaming
*On my Mercedes App, I noticed some Digital Extras under the four categories have a dull blue and under code states Activated. Most of the Digital Extras under the four categories are aBright Blue and under code states also Activated. What is the difference? An example is the Digital Key which is a dull blue and states it is Active. I do use the Digital Key on my Apple Watch and iPhone.
*My Audio Steaming-Amazon Music and Apple Music used to be under APPS in Settings, and I could listen to the music that has full Dolby Atmos using the now complimentary Online Connection.. More amazing the sound than Apple Car Play. With the update of MBUX to 3.2.2, the APPS in Settings is gone. There is Mercedes App and Mercedes Store. But no can find the Audio Streaming which my Mercedes App states is ACTIVE. All the dealership technicians have no idea how to get to Audio Streaming with the new 3.2.2. They are waiting for the big Mercedes Guru as my auto stays in the shop after the first A Service and this new update which also gave the Digital Lite Projections today-July 10, 2025.
Any support or clarification to the two above issues would be greatly appreciated. Wolf, as our guru, any thoughts?
Be well and safe everyone.
Roadrunner
For Apple Music, you should see it in the media menu. At least that is where I see it. There is also an app for apple music, but I can't remember if it's an icon on the main zero layer screen or if you have to go into the Apps item first to see the icon. To get to the media menu hit home then tap the icon that says media.
Thoughts?
Roadrunner
Spoke with Tech Department at Mercedes Corporation. Clarification on the buttons for the Digital Extra in Mercedes App. A Dull Blue means active but I cannot disable as is needed like Mercedes Emergency Call, digital key, etc. Bright Blue is active and can be disable or enable. They are checking on the audio streaming like Amazon and Apple Music. The old APP Icon is replaced, as I mentioned, with Mercedes App. My Digital Lite Projection/Animation is Active and should have those options under Menu then Lights then projections to use. Will check when I have my auto back from the dealership. Will keep you and the forum up to date.
Happy Weekend.
Roadrunner
Somebody at Mercedes doesn't think. Disaster!
