E-Class (W214) 2024 -
Automatic Braking
Old Dec 21, 2025 | 10:57 AM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
Automatic Braking
So, Whenever I go into the menu and disable this feature, I expect it to stay turned off, but on the next restart of the car, it defaults back to "on". Is there a trick to getting this to stay turned off?
Old Dec 21, 2025 | 11:58 AM
Hicksra's Avatar
GL450, E450, Porsche 718 GTS
It may be a safety feature that can’t be turned off permanently.
Old Dec 21, 2025 | 01:41 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
Why do you want it off? Is it engaging when you don't want it to engage?
Old Dec 21, 2025 | 03:15 PM
300SE1993's Avatar
Yes, it beeps at me for no reason. I think it gets confused by shadows.
Old Dec 21, 2025 | 03:48 PM
WZ214's Avatar
Mazda CX-5
Mine acted twice. Both times useful. No shadow or random ones.
Old Dec 21, 2025 | 04:21 PM
superswiss's Avatar
2019 C63CS
No, there is no trick. It's a safety system that defaults to on, just like ESP. You can temporarily turn it off for the current drive cycle, but as you observed, it will turn back on the next time the engine is started. The thinking behind it is that the system safes lives if its on, so turning it off must be cumbersome in order to discourage drivers from doing so. Starting September 1, 2029 it's going to be mandatory in the USA, so it must default to on. For now it's done so voluntary.
If it keeps beeping at you, you are following too closely to other cars. There's a setting that lets you control how soon you get the beeping. You can change that to Early, Medium or Late. You can change it to Late, then it doesn't warn as eagerly, but it also doesn't give you a lot of time before it slams on the brakes. The acoustic warning gives you time to take the foot of the throttle for example to signal the system that you are aware before it decides to slam on the brakes.
As much as I like to think I'm infallible, this system has on several occasions reacted much faster than I was able to step on the brakes and probably saved my bacon a couple of times.
Old Dec 21, 2025 | 04:30 PM
ua549's Avatar
In 2019 I had a bad experience with automatic braking. I had slight bruises on my chest from the seat belt retraction. Here is an excerpt from my NTHSA report.
Complaint Number: 11192423
Vehicle Identification Number: WDDZF4JB6JA305470
Your Vehicle's Make Model and Model Year: MERCEDES BENZ E300 2018
Note: Your VIN, make, model, and year are all protected under the Privacy Act.
What part of your car was affected? Speed Control
What happened?
The vehicle was in motion traveling at 35 mph and controlled by adaptive cruise control set at 35 mph. The time was 12:40 pm ET on 29 March 2019. Seemingly the car went
into crash prevention mode by tightening the seat belt and executing a maximum force braking stop. The tires squealed. My chest was sore where the seat belt retracted with
force. Approximate Location: Southbound on Landmark Dr. near Ashcroft Ct. Clearwater, FL 33761. Landmark Dr. is a residential two lane road running North-South with dual
yellow painted center marking. Road is straight and flat for approximately .2 mile in each direction. There were no other vehicles, pedestrians or animals within sight in either
direction. Weather was sunny and dry with the temperature near 82°F.
When did this happen? 03/29/2019
How fast were you going? (in mph) 35
About how many miles were on your vehicle at the time of the incident? 7805
Old Dec 21, 2025 | 05:00 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
What was the outcome of the NTHSA report? Did you ever have it happen again? Do you still own the car?
Regarding the OPs question. There is no trick to disable it permanently that I'm aware of. I doubt shadows are causing it to beep, but that's just based on my own experience. I've never had it beep or engage when I thought it shouldn't. In fact, there have been many situations where I was surprised it didn't react. Not that I thought it should, but where I thought it would be fooled. You also mentioned in another thread that you don't have active lane keep assist so you don't get that "weird steering glitch". Perhaps your driving habits are causing some of your issues. There have been past discussions of people who like to hug the line or like to merge in between cars aggressively that don't like the car beeping or correcting their actions. Maybe it's defective cars or poor system design, but I suspect it's more likely just driving habits that are outside the design parameters of the safety systems. It's not able to read the driver's mind and has only telemetry data to go on to make a decision. It works quite well from my experience, but I'll admit that I sometimes expect it to misread the situation and I get mentally prepared for it to do something that I don't want. So far, it has not, but I still do not trust it 100%.
Old Dec 21, 2025 | 05:01 PM
GregTR's Avatar
2014 E350 Wagon, 2025 GLC 350e, 2026 E53 Wagon
Looks like the CLA may have this phantom braking issue too.
I have a 2014 W212 with this system that was fairly new tech back then and mine never did this in 250k miles. I also have it in my Audi RS etron GT and my wife's Audi A6 Allroad where I have not experienced this ever.
Old Dec 21, 2025 | 08:04 PM
liexpress's Avatar
2024 E450
I experienced unwanted braking a few weeks ago. I was driving around 70mph on the highway passing a truck on the right. The car in front of me was far away, which was definitely beyond safe distance according to my experience in this car. The car just hit the brake heavily, significantly reduced the speed. I was driving east bound so it could be the shadow of the truck that caused the braking. Luckily there weren't cars behind me, otherwise I could have gotten tailgated.
Old Dec 21, 2025 | 08:57 PM
Hicksra's Avatar
Mine has beeped at me a few times for no discernible reason. I believe most times it was when taking off from a red light. I suspect that the car behind ran up pretty fast and it was trying to warn me of a possible rear end collision. Never a big deal to me. Just a humph, I wonder what caused that?
Also, once when a car in front of me was turning right onto a side street, I ran up on it pretty fast knowing it would be gone when I got there and the seat belts suddenly ratcheted in tight and the brakes almost locked up. I just felt that was a reassuring sign that the feature is working and could help save me in a real situation.
I’d never turn it off.
Old Dec 22, 2025 | 07:13 AM
ua549's Avatar
I corresponded with a NTHSA agent a few times to provide more specific details of the event. I had no discussions with MB. It was a one time event that never recurred. I still have the car - now with 27k miles on it. It will most likely stay in the family another few years until it has 50k miles.
Old Dec 22, 2025 | 05:54 PM
300SE1993's Avatar
I never said it keeps beeping at me. It only happened once, but once is too many times. As others have reported with various cars having this system, it could brake for no reason under certain circumstances. It could cause an accident or other problems.
Old Dec 22, 2025 | 05:59 PM
superswiss's Avatar
2019 C63CS
All safety systems can have an occasional false positive. It's more likely to prevent an accident than to cause one. There are examples of people having gotten trapped in their cars unable to release themselves form their seatbelts after an accident. Is that reason to not wear a seatbelt at all? Both are fallacies.
Old Dec 22, 2025 | 06:35 PM
300SE1993's Avatar
You seem to be very opinionated and you are not contributing positively to my thread so you can just go away now.
Old Dec 22, 2025 | 06:42 PM
Hicksra's Avatar
Maybe if you’re so incensed by other people’s opinions, you should go away. Everyone is entitled to their own opinion and/or input. This is a discussion forum..
Old Dec 22, 2025 | 06:44 PM
geektoad's Avatar
26 E53 Wagon
You kinda did.
Old Dec 22, 2025 | 06:49 PM
superswiss's Avatar
2019 C63CS
Dude, GTFOOH. This is a public forum full of opinions. If you don't want opinions, don't come here and post. What a sorry POS.
Old Dec 22, 2025 | 07:26 PM
300SE1993's Avatar
I've been a member here for well over 20 years and have had positive experiences here for the most part, but for some reason there are just a larger portion of rude W214 owners than in the other sections. Duly noted. I did appreciate those who came here to help and share though. People who feel the need to belittle others in a forum baffle me. I hope you feel better about yourselves for putting me down.
Old Dec 22, 2025 | 07:41 PM
superswiss's Avatar
2019 C63CS
Again, I only shared my opinion and experience as I and others do here. I have more likes on this forum than you have total posts, so lets be real for a moment. I'm a large contributor here. Somehow you took my opinion/advise as belittling or an attack on you and you told me to go away because I wasn't telling you what you wanted to hear. I neither attacked you or belittled you. Your go away comment came out of the blue. If you think people are unfriendly around here, you only need to look into the mirror. I don't feel good or bad about anything. I'm just here to share opinions, experience and advise. You mean nothing to me personally. I would have to be emotionally invested first to get any joy from putting you down as you put it. I just responded to your unfriendliness. Merry Christmas and I hope you feel better next year.
Old Dec 22, 2025 | 08:28 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
A bit quick to come to conclusions here. I didn't think anything superswiss said or anyone for that matter was rude or out of line. Some of your recent posts on the W214 board seem to indicate you jump to conclusions fast. Your bugs thread on two things that happened one time and your calling them bugs are an example.Your car beeps at you one time and you post a message that made it seem it was happening multiple times to where you needed to disable emergency brake assist permanently. I think you would get more helpful discussion if you provided better context around your posts and then assume positive intent from replies rather then immediately jump to a conclusion. Your early posts and videos on the W214 were helpful. Your more recent ones, not so much.
