E-Class (W214) 2024 -
2026 e350 Built-in Dashcam: Input?
Old Jan 19, 2026 | 06:55 AM
ivywood2000's Avatar
2026 e350
Hi All, My new e350 comes equipped with dashcam capability (for what appears to be a one-time fee of $200 to activate). If I understand this correctly (input please), it stores front-only dash cam footage on my own thumb drive. I've read to get a 1-TB drive, and weeks of data can be saved on it. Here are my questions: IF I active this feature, the purpose is to record any front-end collisions with a car, person, or whatever. For those who have this, is the quality good enough? Next, given that I haven't studied this part of the owner's manual, does it automatically record every time I drive, or do I have to manually turn it on every time I start the car? Any other considerations about its use, and pros/cons?
I've considered after-market dashcams which are undoubtedly more versatile and more clear. But they all seem to accompany unsightly wires, unsightly and/or large difficult mounts, continual recharging. I'd like to avoid those, IF the built in dashcam is adequate. Help! Input and direction would be great from those who use it or tried it.
IF it is a one-time charge of $200, seems like a small investment. Thanks!
Old Jan 19, 2026 | 08:58 AM
ua549's Avatar
It is a one time cost. The dashcam automatically starts when the ignition is turned on. There are so many settings and features that you must read the manual. For example it can automatically record if the vehicle is bumped. There is an optional rear camera for the system. The bottom line is that it is designed explicitly for the MB and is "built in" not appended with brackets and dangling wires.
Old Jan 19, 2026 | 10:48 AM
Hicksra's Avatar
GL450, E450, Porsche 718 GTS
It can be set to come on automatically when the car is started. Clarity is very good IMO.
Old Jan 19, 2026 | 11:17 AM
McNeo's Avatar
W214 E350
Isn't automatic recording already a feature by itself when the vehicle detects it's been bumped or a collision involved?
Old Jan 19, 2026 | 11:54 AM
geektoad's Avatar
26 E53 Wagon
That manual has absolutely nothing to do with the built in dash cam in the 2026 E350. in the 214 the dash cam is a Digital extra that makes use of the existing cameras, there is no physical component to it.
OP: It's a good option. I've had it on both 214s i've had. For $200 and the cost of a USB-C drive (which i already had), it's nice. Turns on automatically when you start the car, rolls over the oldest recordings for space, and the camera quality is good. I only have 512GB and given the amount i drive it holds about 30 days worth of recordings. To me, the biggest bummer is that there is no rear camera because the rear cameras are tucked away when not in use.
Will a dedicated dash cam have more features? Yes. better image quality? Yes. Rear camera? probably. However, i didn't find the extra wiring and clutter or additional cost worth it.
Old Jan 19, 2026 | 11:56 AM
geektoad's Avatar
26 E53 Wagon
Yes if you pay for the digital extras, and you can set it up to automatically send the pictures to your phone in the Mercedes Me app.
Old Jan 19, 2026 | 05:23 PM
BoMB's Avatar
2018 E300 4Matic Sport
Maybe I am missing something -- but if it's set to automatically start recording when the vehicle has been bumped, of if there is a collision -- isn't that too late?
Old Jan 19, 2026 | 06:40 PM
Mercuccio's Avatar
There is an option to turn on the camera recording when you start the car. It keeps recording until you open the door to exit and the driver display is turned off. If you don't select the automatic turn-on, you can turn the camera on by tapping the camera icon in the top right of the screen. You can choose to overwrite recording when the drive is full or stop recording when the drive is full.
I have been pleased with the image quality.
I connected a crucial X10 Pro 2 TB SSD to the central console compartment USB-C port. It draws 0.45 W. I believe the USB-C port will be turned off 10 or 15 minutes after shutting off the car shutting off, but I haven't tested this. A high endurance SD card made for video cameras seems like it would cost less and be a nice option, but I haven't tried one.
It is a $200 one-time charge plus the cost of a USB drive. It links to the car as a "permanently active" digital extra.
Here are the Owner's Manual sections for the E Wagon dashcam. The E350 dashcam should be the same.
Old Jan 19, 2026 | 06:41 PM
Mercuccio's Avatar
I'd be interested in getting an optional rear camera for the system. Do you have a link or part number for the rear camera?
Old Jan 19, 2026 | 06:51 PM
Mercuccio's Avatar
Where do you set this up? I haven't seen any documentation on how Guard 360 works.
Old Jan 19, 2026 | 10:58 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
This may be some help to both of you
https://mbworld.org/forums/e-class-w...ml#post9133148
Also, I believe Collision Notification (a.k.a. Guard 360) is only for when the car is parked. It's not something that will give you photos in the event you are in a accident while driving. The dashcam is for that and limited to forward only. No rear option at all as far as I am aware.
BTW: Some advice to all is to read through old threads and use the search feature. The same questions are being asked over and over that would easily be answered with a little search effort. I found my post referenced above by searching.
Old Jan 19, 2026 | 11:20 PM
McNeo's Avatar
W214 E350
I don't know the exact mechanics behind the GUARD 360 collision detection system, but I know it works for sure, as I personally experienced the system before and was able to see the vehicle that the impact occurred with.
Old Jan 20, 2026 | 01:32 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
I'm assuming the cameras are always recording in a looped buffer so it has the last x seconds at any given time. If an impact happens it saves those images, not video, for later review. The link I posted above has some images from a time a very loud exhaust triggered mine.
Old Jan 20, 2026 | 01:46 AM
Mercuccio's Avatar
The linked thread above did explain Guard 360 well. Now that I know it is part of Vehicle Collision notifications, it makes sense.
I tried searching "Guard 360" in the "Search Threads" box. That didn't help at all. Maybe I don't know how to search on MBWorld,
Old Jan 20, 2026 | 06:28 AM
2026 e350
Thanks for all that input. The manual ua549 attached is 56 pages! But it sounds like for forward recordings it works good. I don't know about collision video or pics. I have the mercedes phone app. My car is in a specialty shop getting PPF and ceramic coating. Twice now, I got notification of "collision detected", with an aerial picture of generic car and a red line along the right driver side. The car would not be being driven during at the time of those notifications so somehow that detection thing works with the engine off. And if pictures or videos are available, I have no idea if/how to retrieve them. The shop tells me nothing at all has hit the car. Someone's @ss bumped it while working on it?
Old Jan 20, 2026 | 08:08 AM
geektoad's Avatar
26 E53 Wagon
They probably put it on a lift. I had mine go off when the car was in valet once and it was because they had put it on a parking lift. Same thing happened. I got the notification and asked them about it it after i verified the car was fine. They said that they hear it all the time from mercedes owners that they got a collision notification when they put it on the parking lift.
Old Jan 20, 2026 | 11:53 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
The collision detection is only while the vehicle is stationary and engine not running. Basically parked. Even loud noises will trigger it. A loud exhaust triggered mine. I was inside not more than 30 feet away from the locked car. Heard the loud truck race by and not more than 30 seconds later I get notified of a possible collision. Immediately went out to inspect the car thinking he side swiped me as I was close to the edge of the road. Nothing and the photos had the image of the truck passing by. I got another alert when I was looking at the car through the window of the tire shop while new tires were being mounted. It was right when the car was lifted. Nothing touched the car other than the lift itself. You must setup picture download while in the car. It's a bit more complicated than it should be for security reasons. Once you do, you are supposed to be able to see the pictures from your phone but it takes time for the car to upload them and them becoming available for you to view them on your phone. You can always see them in the car. The phone takes extra setup one time.
Old Jan 21, 2026 | 10:29 AM
geektoad's Avatar
26 E53 Wagon
Still shot of the built in dashcam. It's 1920x1280. The still looks like crap, but the video is clear.
Old Jan 21, 2026 | 04:04 PM
2026 e350
Looks good! I think the $200 is worth it. On a side note, I still don’t understand the feature (if I have it), a picture of a collision elsewhere on the car. The motor off? While moving? I might be getting things confused. I thought this is only a front facing dash cam as in the picture you sent.
Old Jan 21, 2026 | 05:25 PM
Hicksra's Avatar
There are cameras all around the car. To my knowledge, the collision picture is only possible when the car is parked.
Old Jan 21, 2026 | 06:36 PM
Alan Smithee's Avatar
^ Is this automatically activated with the dashcam (or at all related)? I have the dashcam working fine...I do not recall seeing anything about activating Guard 360 (or whatever they call it)?
Old Jan 21, 2026 | 07:30 PM
ua549's Avatar
Guard 360 is a digital extra.
Old Jan 21, 2026 | 08:27 PM
^ Thanks. I see on the app it is called 'Theft Notification and Parking Damage Detection' and is already activated...I guess that means it's good to go.
Old Jan 21, 2026 | 10:26 PM
geektoad's Avatar
26 E53 Wagon
If you have it, go into the settings for it and set up sending the pics to the app on your phone. Nothing like having the app tell you something has happened but not being able to see if it was real or a false positive until you get back to the car.
Old Jan 21, 2026 | 11:29 PM
CaprichioArabe's Avatar
E450 Wagon, GLC300, E550
Several years ago, I parked my previous E450 wagon at the airport. After my plane was in the air, I noticed that the MB app was showing that my car window was open even though I was sure that it was closed when I had parked. I was concerned that someone may have smashed my window or otherwise broken into the car.
My wife called the MBUSA customer assistance number listed on the app, but they would neither confirm nor deny the status of my window and said that they were unable to do anything. Airport customer service refused to send their parking lot security staff or the on-site sheriff deputies to check the car for a possible break-in. My niece was working security at a local college and drove their marked car to the airport to check my car (security did allow her to enter the garage without paying, whooopi!). The window was up and the car was fine. But being 35,000 feet in the air moving farther and farther away from my car with no authorized officials nor MB willing to help me was a bit unsettling.
I hope the notification system on my new E450 works as advertised. I believe some BMWs allow you to remotely capture images from the car’s cameras whenever you want. It would be nice, and probably not a difficult software update, for MB to do the same. Between the external cameras and the interior selfie camera, it could provide peace of mind. I can’t think of a better use for the otherwise goofy selfie camera.
