E-Class (W214) 2024 -
Different W214 headlights
Old May 20, 2026 | 09:02 AM
Tseg's Avatar
W214 E450
I recently picked up my 2026 E450 (US) and I noticed my headlights do not have the LED at the bottom of the headlight. Most pictures on the web show the version with top and bottom LEDs. I then found a website depicting my headlight (top picture) vs. what is commonly seen on the web (bottom picture). I'm assuming the bottom picture headlight is an upgrade or different trim? I have not really found much on the web about the differences. Can anyone inform me?
Old May 20, 2026 | 09:36 AM
Tseg's Avatar
W214 E450
I finally found the answer by "building" my car on the MBUSA website and see there is an "active" LED headlamp upgrade, which mine does not have, to get that bottom LED. Question solved.
Old May 20, 2026 | 09:37 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
You have the standard LED headlights. The upgraded package is called Digital Light LED Headlights. This is what MB says on the options page for the E450.
Pioneered by Mercedes-Benz, active LED headlamps can generate light that's perceived much like natural daylight. DIGITAL LIGHT advances this technology with even higher resolution and a greater scope of adaptive functions. In addition to Ultra Wide Highbeams and Adaptive Highbeam Assist, the headlamps can also adapt more precisely for curving roadways and certain weather conditions. When the low-beam headlamps are on, integrated cornering lamps can help brighten turning maneuvers based on driving speed, turn-signal application and steering angle.
Take a look at mbusa.com and build an E450 to see all the available options along with descriptions.
Old May 20, 2026 | 09:38 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
I was typing my response while you were typing this. Glad you figured it out.
