E55 AMG W211 Vendor Classifieds Forum Specific Vendor classifieds - Test sub-forum
E55 AMG W210/W211, E63 AMG W211 2-piece light weight rotor (save now $$$$$)
Old Feb 14, 2013 | 02:57 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
E55 AMG W210/W211, E63 AMG W211 2-piece light weight rotor with brake pads!
Hi Mb enthusiast, we are now offering our center mount rotors with convergent vanes and open slots for the 2003-11 E55 AMG & E63 AMG. These rotors are the sport tuned type, best and latest technology in the market today, superior to oem and competitors. These rotors are the best in the business it will outperform any high end or any track two-piece rotor out there and the positive feedback we have been getting about its performance is enormous. These rotors are exclusively designed and engineered to prevent from cracking and warping suitable for any kind of driving condition. The mass reduction on the front is 5.0 lbs. the rear is 8.0 lbs. by far the lightest rotor out there for any Mercedes application, lighter rotors means better performance at the wheels and don't be surprise, if your gain extra 15 to 25 whopping horsepower after installing these rotors. Better miles per gallon is also an advantage with these rotors because of the lighter mass rotation all four wheels. This is your chance to gain those hp back that was lost with the heavy oem and other competitors rotors. It is proven that a lighter rotor can increase horsepower at the wheels check the dyno testing.
Front rotor weight Comparison
OEM Rotor 29 lbs.
RB 2 Piece 24 lbs.
Weight Savings: 5 lbs.
Rear rotor weight Comparison
One-piece 21.5 lbs.
RB 2-piece 15.5 lbs.
Weight Savings: 8 lbs.
Total weight saving: 26 lbs.
2003-11 E55 AMG & E63 AMG FRONT 2 PIECE ROTOR - $1,495.00
2003-11 E55 AMG & E63 AMG REAR 2 PIECE ROTOR - $1,249.00
MBWorld members receive free shipping to the lower 48 states using coupon code
MBW-SHIP!
offer valid until the end of June.
Check our RacingBrake 2 Piece Rotor Review!
These rotors are engineered to be the best stock replacement two-piece rotors on the performance market. These rotors are direct bolt-on, easy to install, no additional hardware needed, and an excellent upgrade for both streets and track. Not only will the rotors last 3, times or more longer than competitions' two-piece rotors, they can deliver consistent brake torque under extreme heat, session after session. When it comes to replacement, the operating cost over the time will be lower than one-piece rotors.
RB offers a complete satisfaction guarantee to you and other MB enthusiasts; if you don't agree that they are the best two-piece rotors in value, look and performance your money can buy just return them for a refund.
• Has the advantages of both drilled & slotted rotors.
• Allows the disc to expand and contract and prevents the disc from cracking or warping.
• Increasing cooling area and retains more friction surface.
• Slots relieves thermal stress.
• Slots are self cleaning and the pad build up will not clog the slots and are exhausted via the rotor edge keeping the disc surface clean.
• Reduces brake pad dust buildup and keeps the wheel clean through vacuum effect.
Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated
Machining: Straight Slot
Surface: EDP Coating w/cross cut grinding on friction surface
Racingbrake Technology
Old Jun 24, 2014 | 04:35 PM
CLS550
Free shipping ends soon!
Old Jun 24, 2014 | 11:14 PM
MindBend's Avatar
'05 E55
What is the cost when the disc needs replaced?
Also, what is the lead-time required?
Thx
Old Jun 25, 2014 | 12:38 PM
CLS550
Thx
Front replacemet ring $752.66
Rear replacement ring $626.31
what are you referring to lead time?
Old Jun 26, 2014 | 08:31 PM
OCAMG55's Avatar
2005 SL55, 2010 E550
Originally Posted by RacingBrake
Is this ring are the direct replacement for ornignal benz disc. or only work with RB rotor.
Old Jun 27, 2014 | 01:46 PM
CLS550
They only work with our RB two piece rotor.
