E55 AMG W211 Vendor Classifieds Forum Specific Vendor classifieds - Test sub-forum
AutoTalent | Renntech Ecu + Airbox + Intercooler + Exhaust For Mercedes-benz E 55 Amg
Old Nov 29, 2019 | 03:26 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Stock Performance
469 HP @ 6,100 RPM; 516 LB-FT @ 2,650 RPM
Modified Performance
517 HP @ 6,100 RPM; 552 LB-FT @ 2,650 RPM
Renntech Performance Carbon Fiber Airbox
Click HERE to order Carbon Fiber Airbox!
Click HERE to order Carbon Fiber Airbox Package!
RennTech optimizing the path and increasing the volume of incoming airflow, RennTech carbon air box is able to offer gains up to +10 hp and + 10 lb/ft, in addition to serving as an attractive under hood showpiece. RennTech kit comes complete with high flow performance filter inserts and anodized aluminum MAF sensor retaining clips. Using the highest quality pre-preg carbon fiber, our 4-piece airbox kit for the 63 series biturbo M157 engine comes complete with flow optimized turbo tubes to maximize engine performance by increasing the volume of incoming airflow. The carbon fiber airbox was designed, engineered and manufactured in the USA using only industry leading materials to ensure long lasting durability and appearance. The Carbon Fiber Air Box kit includes a Set of 2 BMC high performance air filter. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary air box offers incredible performance gains and rock solid daily driver reliability.
Features
Increasing the volume of incoming airflow
Increasing the engine's rev limiter
High flow performance filter inserts
Gains up to 10-15 HP & +10 TQ/ft
Long-lasting and driver reliability
Increases the performance
Carbon fiber material used
Incredible performance gains
Renntech Performance Package
Click HERE to order R1 Performance Package!
Click HERE to order R2 Performance Package!
The RennTech R2 Performance Package is the perfect entry level performance upgrade for the E 55 AMG. Performance package R2 takes performance to the next level and is a step up from our R1 tuning package. The R2 performance package includes the same components found in our R1 package with the addition of a full carbon fiber airbox, RennTech stainless steel exhaust headers, 82 mm throttle body upgrade and our high efficiency intercooler pump. The addition of the upgradation helps the engine to perform well and better. The R2 performance package for the Mercedes E 55 AMG engines includes Performance package R2 takes performance to the next level and is a step up from our R1 tuning package. The R2 performance package includes the same components found in our R1 package with the addition of a full carbon fiber airbox, RENNtech stainless steel exhaust headers, 82 mm throttle body upgrade and our high efficiency intercooler pump, this combination that provides huge increases in horsepower, torque and throttle response across the vehicles entire powerband while still maintaining daily driver reliability.
Features
Significant gains in horsepower
Increasing exhaust gas flow
Significant gains torque
Lighter weight exhaust
Improve performance
Sport Muffler System
RennTech HHT - Hand Held Tuner ECU Upgrade
RennTech Crankshaft Pulley
RennTech Full Carbon Fiber Airbox
82mm Throttle Body Upgrade
Stainless Steel Shorty Headers
RennTech High Flow Intercooler Pump
Renntech Suspension Toe Link Kit
Click HERE to order Renntech Suspension Toe Link Kit!
Adding a RennTech toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. When used with our adjustable camber bushings, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort. The RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics.
Features
Ensures the vehicle tracks.
Maintains stability at high speed
Improves handling by total package method
Ipossibility of fine adjustments to the suspension
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech Five Speed Transmission increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. Renntech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech 722.6 Five Speed transmission upgrade consists of a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings, electrical connectors as well as a new transmission pan filter. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1!
Click HERE to order Renntech Performance Brake Package 4!
Click HERE to order Renntech Performance Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
Renntech V3 Digital Suspension Lowering Module
Click HERE to order Renntech DSLM!
The RennTech V3 Digital Lowering Module (DLM) is designed to work with all available Mercedes Airmatic or ABC (Hydraulic) Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The DLM requires no splicing or soldering to the factory wiring harness. The RennTech harness utilizes the factory pins as to allow a completely reversible installation. The unit also supports speed-dependant lowering that allows the vehicle to return to its factory ride-height at a pre-set speed. This removes the need for the vehicle to be aligned after lowering. The user can maintain the factory longevity and still have the lowered look at low speeds. All RennTech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features
Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 53mm x 73mm x 24mm
Weight: 1.2oz
Renntech Locking Limited Slip Differential
Click HERE to order Renntech LSD!
Simply explained, a differential is the last point between the engine and the wheels where power is transferred. The differential functions as a system to direct engine power at the wheels while allowing them to rotate at different speeds. By upgrading the differential, you benefit in both straight line stability and vehicle handling while cornering. During a full power straight line run, RennTech LSD (limited slip differential) will lock 100% and provide torque equally to each powered wheel, providing stable straight line runs. When exiting from a corner, RennTech LSD's transition to the full 100% lock position is smooth and predictable. This gives the vehicle better traction and stability throughout the corner, improving overall lap times and a noticeable improvement in overall vehicle handling. The track is not the only place where the differential comes into play though. Bad weather and harsh road conditions can make the street a dangerous place. In snow, ice, wet weather and regions where the road surface can become unstable, our LSD easily adapts and adjusts tire rotation to increase vehicle stability on the road and help to dramatically improve driver safety. RennTech differential is a unique, patented, clutch- type LSD which makes this a true100% locking differential. Because of this function, there is no movement of internal parts, leading to less heat being generated while in operation and in turn, less wear of the friction disks.
Features
A noticeable improvement in overall vehicle handling
Provide torque equally to each powered wheel
Provide stable straight line runs
Gives the vehicle better traction
Stability throughout the corner
Improving overall lap times
Provide straight line stability
Increase vehicle stability on the road
Help to dramatically improve driver safety
Renntech Exhaust Headers and Sound Performance Pipe
Click HERE to order Renntech Exhaust X-Pipe!
Click HERE to order Renntech Exhaust Headers!
RennTech performance and sound pipes with integrated x-pipe bypass the stock Mercedes resonators for more volume and a better sound. Combined with RennTech ECU software and stainless steel headers, the sound pipe produces more power in the mid-to-high rpm range. RennTech High-strength 304 stainless steel construction ensures lasting quality and a rich, consistent sound. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary Exhaust Stainless Steel Sound and Performance Pipe offers incredible performance gains and rock solid daily driver reliability. Designed, engineered and manufactured in house specifically for your Mercedes Benz. RennTech purge welded, ceramic coated long tube headers feature top of the line big tube 2" diameter T-304 stainless steel tubing and are manufactured from the same high quality materials used on all RennTech headers. RennTech ceramic coat our headers to retain heat within them and minimize latent heat in the engine compartment and combats against thermal stress. Ceramic coating also increases exhaust-gas velocity as hotter gasses expand quicker allowing them to travel faster. By ensuring the internal header bore surfaces are smooth; turbulence is further reduced. The net result is more effective cylinder scavenging, which again offers a power increase. The headers are the perfect complement to sound and performance exhaust and increase performance an additional +30 HP and +30 LB-FT. RennTech Downpipe Kit for installation of RennTech Long Tube Headers are available with a catalytic bypass.
Features
Highest quality T-304 stainless steel exhaust headers
Reduce latent heat in the engine compartment
Advanced computer aided design
Ceramic-coated exhaust headers
RennTech headers are hand built
High quality meterials used
Looking more aggressive
Design is perfect
Simple to install
Renntech Rear Camber Bushing Kit
Click HERE to order Rear Camber Bushing Kit!
RennTech fully adjustable rear camber bushing kit allows for a greater range of rear camber adjustment. This ensures proper suspension alignment to maximize perfomance and handling under all driving conditions and and is the companion component to our adjustable toe link kit which is required. RennTech's kits ensure proper suspension alignment to maximize perfomance and handling under all driving conditions and and is the companion component to their adjustable toe link kit which is required.When used with RennTech's toe link it, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort.
Features
Proper suspension alignment
Rear camber adjustment
Maximize performance
Maximize Handeling
Renntech Performance Torque Converter Upgrade
Click HERE to order TCU!
The RennTech lock-up clutch upgrade uses a multi-element clutch upgrade with additional layer of friction material between the clutch plate, better friction material on the clutch face and a larger surface area of friction material to help control slippage. This allows for better heat management and increased holding power. While slippage in the torque converter is important under acceleration, this slippage becomes a liability once cruising speed is achieved. The lock-up clutch controls this slippage and creates a solid connection between the engine and transmission. If the load on the clutch is too much, slippage can occur leading to excessive heat and wear.
Features
Larger surface area of friction material to help control slippage
Allows for better heat management
Increased holding power
Better friction material
Renntech Performance Intercoolers
Renntech Performance Intercooler Pump Upgrade!
Renntech Intercooler Pump Upgrade Kit!
RennTech latest second generation intercooler pump out performs any other unit on the market; flowing over twice as much coolant as the problematic OEM pump and significantly more than its predecessor. Testing showed our Intercooler pump Testing showed our Intercooler pump flows an impressive 8.7 G.P.M. @ 11.6 P.S.I. compared to the OEM pumps 3.00 G.P.M. flow rate. This increase in flow dramatically removes heat from the incoming air; allowing for a denser air/fuel mixture and substantially cooler charge air temperatures over the entire operating range. RennTech pump upgrade kit mounts in the OEM location without any modifications, due to its dramatically smaller size and lighter weight and comes complete with all necessary plumbing, electrical connectors, mounting hardware and installation instructions.
Features
Second generation intercooler pump
Out performs any other unit on the market
Removes heat from the incoming air
Allowing for a denser air/fuel mixture
Substantially cooler charge air temperatures
Smaller size and lighter weight
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Old Dec 31, 2019 | 03:21 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jan 7, 2020 | 03:20 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jan 17, 2020 | 08:11 AM
AutoTalent's Avatar
SPONSOR
G55
Bump!
