CUSTOM SS X pipe 55 Kompressor
Old Jan 30, 2009 | 02:12 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Selling a custom made X pipe for all 55 Kompressor motor exhaust. This High quality SS steel 2.75" pipe is designed to replace secondary cats and free HP. Also included are extra bends and sections of 2.75 ID pipe.
X pipe will need to be installed by an exhaust shop, as this is a weld in part. Shop can also alter parts to be made to bolt on as well.
Most custom X pipes will run $500 plus but only asking 350.00 for everything.
Paypal is the prefered payment method.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 2, 2009 | 12:36 AM
Iggy_Type_R's Avatar
Chrysler 300C SRT8, BMW 650I Cab, AMG SLK55
Any way of making it fit an slk55?
Old Feb 2, 2009 | 02:29 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
cats
so they are suppose to mounted where the second cats are- I dont see any bends on the actual x pipe- is the e55 exhaust different than a e63
Old Feb 2, 2009 | 11:42 AM
PLATINUM SPONSOR
2003 CL55
Sorry, not familair with the SLK exhaust..
Old Feb 2, 2009 | 11:47 AM
PLATINUM SPONSOR
2003 CL55
Yes, this will fit and E55, S55 or cl55. The wide part of the X connects just after the bends and then goes striaght into your resonator flange. The overall lenght of thisd X pipe is 19" long.. The angles are a perfect match to our system..
There are several restrictions in the stock area of the cat and pipes , that this X will take care of..
Make me an offer..
Old Feb 4, 2009 | 08:22 PM
PLATINUM SPONSOR
2003 CL55
Here is a picture of the restrictive secondary CAT section. Lot of bends and kinks in the way of POWER and FLOW!
I am going with long tube headers and had to give up this custom stainless X pipe. Make an offer!
