FS: 82mm TB (big hp gains)!
PLATINUM SPONSOR
I have an extra 82mm Bosch TB. All the 82mm TB`s need to be adapted to the 55 Kompressor motor blower inlet. This TB will need a plug adaptor to mate up to the MB wires. This is a great TB for anyone that wants to save thousands and peice their own kit together. A new kit can run 1500 plus and the TB alone can cost around 1K..
First $200.00 Shipped takes it!
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
Not sure but you need an adaptor plate, pigtail extension and modify the Y pipe.. Maybe a couple hundred bucks.. Again, just a guess.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Not yet, lot of questions on PM. All you need is an 80mm inlet , TB pigtail adaptor harness, 80mm y pipe, and a TB adaptor plate for the blower inlet. It can either bolt on or weld on like some have done.
