F.S. m111 ASP pulley C/SLK 01-03
C43/2jz, Ml63, C32
Spring cleaning
I have a used ASP modified pulley that came off of a 2002 c230. This will not fit the 98-00 m111 engine. A quick check if your uncertain this wont fit a cluthing S/C but will fit the fixed S/C. The size is 216mm and will bump your boost to 14ish psi. I dont have the belt but according to the ASP pdf you can get a K060560 belt to run it. I currently have one on my 99 c230 and it picked up some major speed for this engine.
Looking for $320 shipped
![](http://i382.photobucket.com/albums/oo270/money-one/DSC00298.jpg)
![](http://i382.photobucket.com/albums/oo270/money-one/DSC00294.jpg)
![](http://i382.photobucket.com/albums/oo270/money-one/DSC00296.jpg)
C43/2jz, Ml63, C32
There are 3 part numbers that ever went on the m111 engine as far as dampeners go 1110300503 1110300903 and the fixed pulley S/c dampener 1110301003. The belt offset is difference.
![](http://i382.photobucket.com/albums/oo270/money-one/69775705.jpg)
