New Bosch 82mm TB
It is a Bosch 82mm TB. TB only, inlet not included. Never used, still brand new.
$600 obo
Aleks
1. 82mm s/c snout or a 80mm s/c snout with an adapter flange to mate the 82mm TB on to it.
2. a plastic Y pipe to accommodate the 82mm TB
3. This TB does not have a PCV inlet so you may have to put a filter on the PCV tubes and vent it to the atmosphere or just drill a hole on the bottom of the TB for the PCV inlet hose.
4. Pins on the TB wiring harness will have to be swapped in order for it to work.
dont let me scare you it is not a hard project.
Where can I source these and approx price? Are they dealer parts/ part #s avail?
Thanks for the help, just making sure it makes sense.
