Mercedes Approved ATF 10 quarts + Trans filter and Pan Gasket $100 Local pickup only
Mercedes Approved Shell ATF 134 10 quarts $100 Local pickup only.
For use in most if not all 5 speed and 7 speed Mercedes transmissions.
Meets sheet 236.14, replaces 236.12 and is backward compatible with 236.10.
I'm in San Jose, CA.
I'll throw in a Trans filter and Pan Gasket if you have a 5 speed, and loan you the dipstick if put a deposit on it + provide you with a DIY from the forum.
PM ME!!
PM ME!!
![](https://mbworld.org/forums/attachments/engine-performance/226063d1326224104-mercedes-approved-atf-10-quarts-trans-filter-pan-gasket-100-local-pickup-only-shell134003.jpg)
