Garage sale! Mez H/E pump, ported heads and more!
MEZ pump is sold!
FS: Only have 4 of these custom made ARP racing crank pulley bolts. These are the best you can use to hold on your crank pulley. These are the same bolts I use on my car and they can almost double your clamping pressure to the crank. the 12 point head, makes for easy torqueing to 250 ft lbs. These are re-usable and come with special ARP torque grease. $75.00 each.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Do you have any part numbers?
www.ultimatepd.com
epc-online.com is a good source for matching up parts.
www.ultimatepd.com
Only the Mez pump left and one ARP bolt.
www.ultimatepd.com
