FS: NEEDSWINGS C32 COLD AIR INTAKE SYSTEM
Old Apr 1, 2013 | 01:39 AM
ROGUE.AMG's Avatar
C32 AMG
I have a like new Needswings cold air intake for a W203 C32 AMG.
I had it on the car for about 6 months then I sold the car.
In great condition asking $650...OBO...
if your interested call me at 408-605-6798 or just message me below are the specs of the intake:
We have designed and built this kit in the “Motor City” Detroit Michigan using the finest materials possible. We went to great lengths to ensure this is a true bolt on kit and no factory parts will need to be modified or destroyed. The kit is built with 3” mandrel bent 6061 billet aluminum tubing, dual high flow enclosed air filters, high-quality 4-ply silicone couplers and stainless steel clamps. This replaces everything from the radiator shroud to the throttle body.
The aluminum pieces will receive the Teflon velocity coating in your color choice of silver, dark gray, black, red, yellow or blue. Please specify your color choice in the "special instructions" section at checkout. The Teflon velocity coating shows increases of 8% on the flow bench over raw aluminum or powder coat.
This kit is capable of flowing 659cfm, whereas the factory intake peaks at 445cfm. This system also significantly out flows the SL55 air intake (which flows a peak of 515cfm).
As an added benefit the supercharger "whine" is very apparent now at wide open throttle yet still quiet when daily driving.
Install should take about one hour.
Old Apr 1, 2013 | 11:39 AM
WaveyKat's Avatar
Something Slow
pictures?
Old Apr 1, 2013 | 02:37 PM
ROGUE.AMG's Avatar
C32 AMG
what your email?
i can email you the pics!
Old Apr 30, 2013 | 05:55 PM
raf12690's Avatar
c32 amg
Sold yet? I was wondering what color combo you went with...
Old May 8, 2013 | 08:42 PM
rrecupa1's Avatar
Crossfire
Still there
Is it still available and do you have pictures?
Old Jun 28, 2016 | 02:46 AM
Reilan's Avatar
W203 2003 C32 AMG
C32 AMG intake software needed???
Hi I just wanted to find out when doing a cold air induction on the C32 must software be done aswell to allow fuel and air ratio to be right?
Old Jun 28, 2016 | 03:24 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Not required but a tune will help a bit
