Barely Used: Shuriken BT20 Lightweight Racing Battery
Price:$50
I bought this for an old V8 project, but need a little larger battery with a bit more cold cranking amps.
I used this battery for only two months, so it is in excellent condition.
The battery is great and has the following specs:
12V High Performance AGM Car Battery
For use with audio systems up to 600 watts
Using AGM (Absorbed Glass Matt) technology can be mounted in any position
Unique spill free design
Extreme heat resistance
Resistant to heavy vibrations
Super low ESR
Packed closely with pure lead plates
100% Sealed and maintenance free
Designed to be used with ring terminals or a buss bar
Amp Hours: 20
Cranking Amps: 850
Weight: 13.5 lbs.
Dimensions: 3"D x 7-1/2"W x 6-1/2"H
This is similar to the Braille (believed to be exact) and the Odyssey PC680.
I paid $80 for the battery and then another $16 for the posts, so I have about $96 into it.
I will sell it for $50 shipping extra. I still have the original box and packaging
Located in Houston
Super low ESR
Amp Hours: 20
Cranking Amps: 850
Weight: 13.5 lbs.
Located in Houston
