2005 c230 kompressor engine part out m271
Old Jun 30, 2013 | 05:11 PM
bmxguy08's Avatar
1995 C36 AMG
So the gear on the intake camshaft stripped (see my other thread with pics) causing metal shavings through the block causing minimal rod knock. there was no valve to piston contact probably could away with micropolish on the crank and new set of bearings and new timing set and it would be a runner again but I just found a good deal on a used motor and swapped it instead. Im open to selling as a whole too.
So now im parting the old motor out has almost everything on in minus the intake manifold and supercharger EVERYTHING else is there. Just shoot me an offer for anything off it. I traded the car in so I don't need any spare parts laying around for this
I also have a 95% complete harness its missing 1 connector that was cut by the wrecking yard that pulled the motor. but im willing to let this go for cheap or even cut off just one plug if you need.
make an offer on anything
there was no check engine light prior so all sensors are in working order
Complete fuel rail with injectors are there
coilpacks are also available
