Complete C36 3.6 engine swap into 190E E320 W201 W124
Old Dec 31, 2013 | 11:44 AM
David Hendy's Avatar
'97 Renntech E60RS
Before anyone gets their knickers in a twist this is an old school AMG 3.6 mmotor swap.
I have a complete C36 engine swap. Its the full 3.6 engine, with all ancilliaries.
I don't have a W202 C36 harness, so this comes with the W124 cam cover & cross over tube, a replacement W124 upper engine wiring harness, non asr throttle actuator and W124 mechanical air pump.
Comes with the engine ecu, the actuator (egas) ecu, klima relay etc
It comes with the three body harnesses, from a W124 for a non asr car, the main harness, the actuator harness and the starter harness.
As I said its complete.
It has the correct brackets etc for the mechanical smog pump & the W124 compressor, I have a nearly new W124 water pump
The engine came from a '96 C36 with 149k miles. It ran great, was quiet (for a 3.6) I have a couple of videos of it running.
I want $2300 for the complete swap.
I have a low mileage (50K miles) 722.369 trans for another $500.
Send me a pm with your email addy if you want the videos.
