WTB: E55 stock Y pipe/bellows
PLATINUM SPONSOR
Just need the Y pipe and bellows that goes onto the throttle body. It is ok, if the a tab is broken off the Y pipe, as that is common. PM me for quick response.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
