Looking for C32 performance upgrades, hoping for Stage I
Old May 3, 2014 | 11:57 PM
supraoleg's Avatar
2004 Mercedes-Benz C32
Hey everyone, I am new on here so be patient with me, lol. But I am looking for a Stage I upgrade for my C32, my car is completely stock now and I just do not want to spend $2,000 on the kit from eurocharged. To be honest, any performance upgrades will be considered.
Old May 4, 2014 | 07:23 AM
Benzaddict32's Avatar
C32x2 RIP, 2005 C55, 2020 GLB 250, 2014 E550
If you're really looking to make you car faster, you would need a larger crank pulley or smaller supercharger pulley from eurocharged. When doing so, I believe you gain +/-20 whp. If you add a tune from eurocharged you'll gain another +/-20 whp. You should also get a pulley saver kit from them as well to prevent belt slippage. The issue is that you will need to upgrade your heat exchanger because with the increased boost, your car will overheat and won't run the way it should. The smaller supercharger pulleys are cheaper than the crank pulleys if I remember correctly, if you wanted to save a couple hundred bucks. I think when you add up all those upgrades, you should be somewhere in the ball park of $2k anyway. All I have is a sl55 intake currently but I have been eyeing these upgrades for a while.
Old May 4, 2014 | 01:03 PM
supraoleg's Avatar
A heat exchanger is just the intercooler right? and I've been wondering if a tune from eurocharged would be the same as going to a place that dynos and tunes my car, do you by any chance know the anser to that?
Old May 5, 2014 | 01:04 AM
C3Duece's Avatar
2002 C32AMG
- larger H/E
- coolant iso
- replace 4 low flow cats with 2 high flow
- smaller S/C pulley
Old May 6, 2014 | 06:17 AM
A heat exchanger helps transfers the heat away from the cooling system. Search the c32 forum on here and you will find many threads regarding these upgrades. I believe the difference between a eurocharged tune and a dyno tune is that the dyno tune is going to be custom. If you're going with mild upgrades, such as pulley and intake, I would go with a eurocharged tune.
Old May 7, 2014 | 09:24 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
I've got a 65mm steel Code3 pulley I don't need. PM me if you're interested.
Old May 10, 2014 | 06:48 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
Have a still in the box full Eurocharged 185mm crank pulley kit and looking for nearly half price. Text me at 774-273-3990 if interested
