FS, UPD big ferrea valve ported race heads M11K
Old Jul 12, 2015 | 11:36 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
FS , Just completed , brand new big vale race heads heads for M113K , E55, CLS55, CL55, S55, etc. $3900 and all reasonable offers will be considered. If you have headers, more boost and upgraded intake system, then these heads are your next best big power gain.
UPD worked with Ferrea many years ago to bring the custom big stainless valves to the M113K format. These high flow race heads are a huge upgrade for the stock and inconsistent factory valves and vale job, that contribute to rough idle and loss of power.
Few process pictures.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 13, 2015 | 11:01 PM
chinatownabc's Avatar
2005 E55 AMG
any dyno sheets?
Old Jul 14, 2015 | 10:17 PM
PLATINUM SPONSOR
2003 CL55
About 30 to 40 people here have these big valve race custom heads on their high HP AMG`s and below is one of my dynos on my cl55. I made about 550 hp before the heads and most my after head dynos made 611 rwhp to 620 rwhp .
__________________
www.ultimatepd.com
Old Jul 16, 2015 | 06:31 AM
99lightning's Avatar
99 ford lightning
I bet even a stock car would see 30 to 40hp gain. with no extra heat.
Old Jul 16, 2015 | 04:08 PM
03svtkiller's Avatar
2011 Cadillac CTS-V
Interesting 30-40whp with only these heads that's a crazy gain. I'm very interested but would like to hear from people who have them.
Old Jul 16, 2015 | 04:11 PM
PLATINUM SPONSOR
2003 CL55
Check with Drollins on this forum.
Old Jul 19, 2015 | 11:02 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Are cams and rocker arms included
Old Jul 20, 2015 | 09:13 AM
PLATINUM SPONSOR
2003 CL55
Rocker arms are included and cams can be if you need those.
Old Jul 21, 2015 | 07:51 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Did you switch over to a beehive style spring set up? Do you have flow bench data for before, and after?
Old Jul 21, 2015 | 09:50 PM
PLATINUM SPONSOR
2003 CL55
Modified amg springs are used with some increased spring pressure to accommodate the stock and mild aftermarket cams. If you need some other custom springs for your build, that can be arranged as well.
Old Aug 4, 2015 | 09:50 PM
PLATINUM SPONSOR
2003 CL55
Bump (winter race season is almost here)
__________________
www.ultimatepd.com
