Complete 6 speed manual swap for an M112
Old Aug 9, 2015 | 06:13 PM
Twichel04's Avatar
1996 C36 AMG and 1999 BMW e46
For sale is a complete 6 speed swap out of a w203 with an M112. This will be a direct plug and play swap for any 203 with an M112. This will obviously fit in other M112 powered cars, but there may be some other parts required to swap into anything other than a W203.
It came out of a 2002 C240 with 135k miles. This is probably the most complete, most well organized, and most likely the cheapest swap around. The swap comes with the following-
-Transmission
-Trans cross member
-Trans mount
-Exhaust hangers
-Shifter
-Shifter bezel trim
-Shift knob with leather boot
-Flywheel
-Clutch (clutch is good, but its an LUK, so you may want to replace it, your call)
-Pressure plate is included, but replacement is recommended
-Drive shafts, with good center support bearing
-Pedal box with master cylinder
-Salve cyl
-Under dash kick panels (just in case they are different for the manual pedal box)
-Hard line for master to slave cyl
-ECU is also included with the swap
-Neutral safety switch pig tail (incase its different)
-Every single nut and bolt that was removed is included. All of them are individually bagged, and labeled with what they are for and what size they are.
I am located in Ocala, Florida. I am willing to pack the swap up for shipping on a pallet, but the buyer will be responsible for arranging shipping and pick up from my home. Asking $850 for everything!
Old Aug 10, 2015 | 10:11 PM
Twichel04's Avatar
Bump. $750. Need it gone, as I don't have a car to put it in.
Old Aug 19, 2015 | 10:38 AM
Twichel04's Avatar
Some financial set backs have come up for me right now, price drop to $500 for the COMPLETE SWAP!
Old Aug 23, 2015 | 09:32 PM
kramykram's Avatar
c32 amg
wow i would be all over this if my wife would learn to drive a stick
Old Aug 26, 2015 | 07:44 AM
slownrusty's Avatar
'06 E55 K2
I am interested but shipping to Houston would be quite expensive. I just had a tranny shipped from LA and it was $250.
Old Aug 26, 2015 | 08:42 AM
kramykram's Avatar
c32 amg
Ship it grey hound bus it will not be so expensive
Old Aug 28, 2015 | 09:09 AM
scboost's Avatar
b5 a4
do you know if this is the same setup as the 6 speed out of the c320??
Old Aug 31, 2015 | 01:24 PM
Twichel04's Avatar
Scboost- I've tried to message you back twice and for some reason it keeps sending you a quote of what you sent, even if I delete it? Give me a call or text @ 352-304-3062
Old Nov 26, 2015 | 03:33 PM
Pocketzest's Avatar
C240 Wagon 6spd, 2005 S600, 2002 CLK55
I
Awe man I wish I could buy this.
Old Nov 30, 2015 | 10:22 PM
zondaf355's Avatar
IMSA BMW E30, Suzuki Hayabusa
Will this work in a 2005 C55??? If so please reply to my PM and let's talk turkey...
Old Nov 30, 2015 | 10:27 PM
scboost's Avatar
b5 a4
I already bought this months ago
Old Dec 11, 2015 | 09:49 AM
6speedclk's Avatar
CLK500
It will work in a c55
Old Dec 11, 2015 | 09:51 AM
6speedclk's Avatar
CLK500
Have you installed it yet scboost?
Old Apr 22, 2016 | 04:02 PM
Eason Lam's Avatar
w202 c240
Hello,still here?
