550 injectors
Old Aug 21, 2015 | 07:34 AM
c55asleep?'s Avatar
Bicycle
550 injectors
Two sets of 550 injectors. One are from fiveomotorsport with less than a month of use paid almost $600 for these. I have the paperwork that comes with it. The second is used from fabtech with the connectors. Both for $500 plus shipping.
Old Aug 25, 2015 | 09:37 AM
c55asleep?'s Avatar
Bicycle
Bump $500 obo
Old Aug 28, 2015 | 12:44 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
So $500 for 16 injectors or $500 for each set? They can be had on ebay for around $300 with connectors new...
Old Aug 28, 2015 | 03:00 PM
c55asleep?'s Avatar
Bicycle
I know they go for 300 on eBay. If you read I put for both sets. Thanks for letting me know. The red ones from fiveomotorsport are not $300 to let you know.
Old Aug 28, 2015 | 04:19 PM
carguyshu's Avatar
what's the difference between the bosch 5-0 motorsports ones and the bosch ones on ebay? I just had an injector break on my SL55 and am looking to just go ahead and replace them all with higher flow units to future proof for mods. My dad's e55 had the same problem a few years ago and I'd imagine he'd be interested in replacing all of his too since only one got replaced when he had his repaired.
Old Aug 28, 2015 | 05:17 PM
c55asleep?'s Avatar
Bicycle
The red ones are direct fit. Doesn't need the pigtail. These are almost $600 new and I purchased them on the last week of July. Installed them August then removed them to sell the car and the stocks back in. The ones from eBay I'm not sure but are probably the same as the second set I have which were from fabtech but these require the pigtail that I have as well. These are about 3 years old and I removed them due to the stutter issue and thought that was the problem but wasn't. Both sets are fine and of course the red ones are almost new.
Old Sep 2, 2015 | 02:11 PM
c55asleep?'s Avatar
Bicycle
Bump
Old Sep 3, 2015 | 11:47 AM
c55asleep?'s Avatar
Bicycle
$450 shipped
Old Sep 9, 2015 | 08:46 AM
c55asleep?'s Avatar
Bicycle
Bump.. $450 for both sets..
Old Sep 16, 2015 | 09:42 AM
c55asleep?'s Avatar
Bicycle
Bump
Old Sep 21, 2015 | 11:25 PM
sealrockswell's Avatar
2003 Mercedes-Benz W211 E55 AMG
These are Bosch right? From what I understand you won't be able to use the fastening clips that secure the connector to the rail with the red ones from 5.0. So the injectors are just floating between the rail and the head. Can you please confirm?
Old Sep 22, 2015 | 07:03 PM
c55asleep?'s Avatar
Bicycle
I had them on my 04 E55 and they worked perfect with no leaks. I just got your message on eBay about wanting to cancel the bid..
And yes the clip does work.. Not sure who told you no????
Old Sep 25, 2015 | 07:36 AM
RedDogNumber1's Avatar
2005 Crossfire SRT6
Some interest in your 550cc injectors
Hi, Looking at your posts here. I suspect the ones with the pigtail are to go from an EV6 connector (on the injector) to an EV1 connector (the OEM harness connector). Those won't work for me. I am, however interested in the other set of 550cc injectors that are plug and play. Would you consider selling just that set and if so, how much?
Old Sep 25, 2015 | 01:58 PM
Shardul from UPD told me they won't work. He has provided most of my performance modifications so I took him at his word on this, although you having said they fit on your E55 now makes me wonder. FYI, PayPal is not showing a canceled bid.
Old Sep 25, 2015 | 02:02 PM
RedDog - he's selling the red ones apart from the black on eBay (see link below) http://www.ebay.com/itm/8-550cc-BOSCH-Fuel-Injectors-Mercedes-Benz-E55-CL55-AMG-FLOW-MATCHED-SET-/262056212973?hash=item3d03c479ed&vxp=mtr
Old Sep 25, 2015 | 08:08 PM
c55asleep?'s Avatar
Bicycle
Sealrockswell, I haven't been able to cancel your bid. Contact eBay and let them know. Has Shardul used them? He's mentioned that his supercharger pulley don't break and well..... I don't want to start a ****ting contest but hopefully you get what I mean. Honestly I have no business selling something if it doesn't work properly. As a matter a fact, Tony from BIP was the person who told me to go with those.. Even fiveomotorsports sells them for that application.
Old Sep 25, 2015 | 08:18 PM
c55asleep?'s Avatar
Bicycle
Reddog, the other set I'm just basically throwing them in the deal. They are missing the seals and were used for about 3 years. The red ones are almost new. I sent you a pm
Old Sep 29, 2015 | 11:30 AM
ctm7676's Avatar
2004 mercedes e55 amg
Sir,is the one with pigtails,plug and play or do you need a ecu tune? thanks
Old Sep 29, 2015 | 05:20 PM
c55asleep?'s Avatar
Bicycle
Either one will more than likely need a tune. Both sets are 550cc. They flow more than stock so they will need to rescale the fuel map. As for the install they both work fine and the clips work for both. The only difference is the red ones will not need to extra plug and the others do use it to work on the stock connector.
Old Oct 5, 2015 | 03:49 AM
johnny_b's Avatar
04 E55 99 SC400 01 Z06 Corvette
Bump this is a great deal if there still available!
Old Oct 5, 2015 | 09:08 AM
c55asleep?'s Avatar
Bicycle
Thanks Johnny, I do believe it's a great deal. They are almost new and I'm selling them real cheap lol. Thought this would've been gone by now lol. Only the fiveomotorsports are available. The other set sold already.
Old Oct 13, 2015 | 09:20 AM
c55asleep?'s Avatar
Bicycle
Sold.
