2004 E55 Rear Differential $300 plus shipping
Old Nov 27, 2015 | 12:38 PM
E55Greasemonkey's Avatar
This place is a joke.
I have a used 98k miles rear differential for sale. Stock 2.65 gearing. Removed from my own car when I went to 2.82 gearing. The holes for the rear cover mounting have stripped threads. You will either need to repair the threads or swap the rear cover off your old diff. The diff is crated and ready for shipping. Pictures coming later. Asking $300 plus shipping, it's heavy.
Old Nov 28, 2015 | 09:20 AM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
I'm interested. In for pics. Where are you located?
Old Nov 28, 2015 | 11:33 AM
I live just North of Orlando FL. Sorry I was wrong about which threads were stripped, it's been a couple years since I swapped it. The threads that go through the subframe into the rear cover are stripped. Just a note, there are several revisions of the oil cooler fins/cover, so the fins that are included with this diff may not fit another cover, if that makes sense. I had to buy a newer version of the fins to fit the cover on the 2.82 differential I installed. Also, this will not fit 2003 E55's as they used bolt-in axles. The bolts for the fins and subframe-to-cover are not included as I used them on the new diff.
Attached Thumbnails 2004 E55 Rear Differential 0 plus shipping-20151128_111914.jpg   2004 E55 Rear Differential 0 plus shipping-20151128_112214.jpg   2004 E55 Rear Differential 0 plus shipping-20151128_112223.jpg   2004 E55 Rear Differential 0 plus shipping-20151128_112249.jpg
Old Nov 28, 2015 | 05:26 PM
WANTED!!'s Avatar
So it will need to be helicoil'd. How flexible are you on the price if I was to come and pick it up instead?
Old Nov 28, 2015 | 07:49 PM
I could go $200 if you want to pick it up...Anything less I may consider just keeping it. I'm located just off an I-4 exit; easy to find.
