EQB: Check Coolant Level message (Easy Fix)
I asked the SA to have the 12 V checked as I got a pre-safe type error after charging a second time, as I suspect a weak 12 V…
I do have a can of coolant lying with me that I got from Amazon. Can someone confirm if this is the appropriate coolant? Also, in 2 minds whether I should top up the coolant. Any suggestions?
https://operatingfluids.mercedes-benz.com/sheet/326.6
https://operatingfluids.mercedes-benz.com/sheet/320.1
The Sheet No. 326.6 should be correct. Zerex G40 would be correct. (Sorry I don't frequent here very often).
I'll try to listen for the air concern I had on a cold morning with heater activated. Hopefully they improved their initial fill technique...
For a gas/air PV=nRT.
For a liquid Pascal's Law/Principle states that all points in the system have equal pressure.
We have two different sized containers somehow connected together, meaning not completely separated, and the temperature on one side doesn't always equal the temperature on the other, the air volumes are not equal to boot...
If you want to try to stop the imbalance your best bet, after getting rid of the air (that our '24 appears to suffer), fill both sides to the brim/top. I also replaced the red cap with a black cap. Not sure why the Mercedes engineers decided to make it that way vs completely separate systems like other manufacturers...
With a 2022 how long ago did you purchase? Was it new? At 3 years old I would advise to bring it to the dealer or reputable EV shop. Make sure they use the correct coolant, if not a Mercedes dealer as there appear to be many types beyond the old sheet no. 325.0, or buy the coolant at the dealer and bring it with you.
You could try what I did with our old '23 EQB lease which was fill both reservoirs to the top with correct mixture of coolant. Not sure if you noticed but opening the driver door will cause some noise and that is actually a coolant pump, the level in one of the reservoirs (the smaller one) goes down and you can add even more but quickly close the cap as it will overflow out as the accumulator relaxes....
Thanks again!
