e-Drive Unit/ Power Electronics Control Unit Software Update
Anyone got the update done? Does it bring any noticeable improvement to the driving range or acceleration?
I have not experienced any issues with my car so far (touch wood) and would hate to go to the dealership and waste half a day (maybe more?). IME with other cars, they always manage to break something that was previously working fine (lol).
Our EQB is already scheduled for its first scheduled free service (USA) in early December and since I’ll have a loaner I’ll ask them to check this while it’s there.
Look forward to that. I might be bringing mine to the dealership in early December for the update. As of now, the dealer is still awaiting further information from MB and shall schedule the appointment when they know for sure what exactly needs to be done.
FWIW, our EQB is absolutely driving differently since it was in the shop and the difference is a noticeable improvement. However, I don’t know if this is the result of this specific update, or if there was other phantom work or calibration resets performed at the same time.
Basically, there is a significant difference when the car’s motors transition from power to re-gen, and then from re-gen to braking. Now the car is extremely smooth when you lift off the ‘gas’ and the car transitions to re-gen. The amount of re-gen is not changed, but the transition itself is now very smooth whereas previously it was usually smooth, but not always. Ditto for the blending of re-gen with physical brakes. Previously the car could be inconsistent in the behavior but now it’s all very consistently smooth, with consistent behavior.
These are minor, but welcome improvements. I’m gonna suspect this software package simply brings the earlier EQBs into alignment with the ‘refresh” 2024 model since the drivetrain hardware itself appears similar, if not identical.
We never DC charge so I can’t share any observations with DC charging.
Yes, I would have liked to see those in my car as well. I am guessing I did not get the 'full suite' of updates. Is there an easy way to figure out what patches have been applied, from within MBUX or the dashboard?
BTW, here is what my work order shows wrt to the update:
Job code: 02-9334-01
Description: Update power electronics control unit software at front axle (SG-LE-VA) (with XENTRY Diagnostics connected)
SAC code: 998714
It would be very helpful if you could list the jobs/ updates that were done when you sent yours for the update. I can compare with mine and take it up with the dealership.
I'm also wondering if there was some sort of a calibration performed after the update on my car which could account for a difference but is not delineated on the receipt?
After you pointed out that the friction brakes now feel smoother, I started paying attention to how the car has been braking. I feelI am able to bring the car to a complete stop more smoothly now. Previously, there was always a jerk in how the car would stop because the motor would maintain power until the last minute before cutting off. Now the motors seem to modulate the power levels a little better and the car does not give as big a jerk when coming to a stop. I was attributing this to my driving skills/ familiarity with the car so far (lol), but you are right, it could be due to the eDrive software update. Shall monitor it for a few days before confirming. Not so sure about the high speed braking - have another long highway drive coming tomorrow. Shall post observations post that.
But to reiterate, I’m perceiving a smoother transition at higher speeds between the traction motors creating power and the switch to re-gen, and again at very low speeds when the friction brakes are blended in. It’s all just smoother and I have not been able to get any jerks or inconsistent behavior which is something that would happen occasionally before.
So that is an area where I feel they need to improve things a bit more because the friction brakes do feel a bit grabby when they are engaged leading to a sudden deceleration and then when they let go, the car seems to feel as if it suddenly picked up speed. Anyway, I shall keep monitoring and share my observations.
