reflection and glare from EQC windshield windscreen on sunny days
https://www.mbeqclub.com/threads/eqc...en-glare.1739/
There is a really distracting and annoying reflection from the dashboard of the EQC. I test drove the car in the winter, no sun. Now in June it is really very distracting. And I think that it is so severe that it is dangerous.
The effect can be reduced by adjusting the seating height. Improves, but still terrible and for me not a comfortable solution.
The effect is called veiling glare. I first noticed this effect back in the early 00's with a Volvo V70 that had a raked windscreen and a light coloured dash board.
You can find some info here.
https://www.diva-portal.org/smash/ge...FULLTEXT01.pdfFord took a big interest in the late 1990s.
Fundamental Issues in Automotive Veiling Glare
The veiling glare effect in automotive vehicles consists of diffuse and specular scattering of sunlight onto and from the windshield. This effect occurs over a wide range of solar elevation angles and increases with increased degree of inclination of the windshield. Thus its effect on visual acuity
US8467129B2 - Veiling glare reduction system and method of controlling reflection from a vehicle windshield - Google Patents
A vehicle glare reduction system is provided, which improves the visual acuity of the vehicle operator in vehicles having a light-colored dashboard. The system includes a dashboard having an upper surface from which dashboard light is reflected; a windshield having an inner and outer surface...
patents.google.com
The problem with the EQC as far as I can see is a shiny grey dash. With a perforated surface that accentuates the effect. The windshield installation angle and the driver position must be having an effect also.
Solutions to me seem to be.
Fit a windshield with an antirefective coating with the optics tuned to the angular set up of WS vs dash. Quite possible. It will significantly reduce but not totally eliminate the effect.
Cover the offending dash board with a matt black cloth. An old T shirt or a bit of black carpet. Not a very attractive addition to an expensive car.
Spray paint the dash with a matt black paint. I think a BBQ paint would good, but no idea if will stick to the dash.
Complain to Mercedes and get them to make a matt black dashboard with no silly holes or go and research the Ford idea of fitting polarising filters to the dash
I'm "happy" that other otherwise delighted EQC owners have the same issue.
Hope this is of some use and I hope someone from Mercedes reads these forums. You made a mistake that is spoiling an otherwise super car
Mikey
