EQE SUV (X294) Forum for Discussion of EQE SUV
DC Charging Error?
Old Mar 31, 2025 | 02:02 PM
Scott Schmidt's Avatar
GLS 450 (2022), EQE SUV 350 (2025). GLS 450 (2007)
DC Charging Error?
Hi folks. I plugged in my wallbox to charge my EQE SUV this morning and I got an error on the dashboard that said "DC charging inoperative - service required". After about 10 minutes, the error cleared and the car began to charge from my wallbox at 9.6kW (the normal rate). Has anyone else had this happen and can anyone explain what this is? Thanks for any help you can all provide.
Old Mar 31, 2025 | 03:23 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
That's interesting. The same pins that are used by AC charging stations to signal to the car the maximum charge current are used by DCFC stations as a digital signal. AC charging stations put a voltage on the pin that indicates charging current available to the onboard charger. The DCFC stations use a digital communications protocol over the same pin(s). It's possible that the car was confused during the connection process and thought it was getting a connection handshake or some sort of preamble and decided it was faulty, thus temporarily disabling DCFC. That'd be my first thought.
Old Apr 1, 2025 | 06:55 AM
Thank you again Bytemaster. Later in the day I again charged my EV and this time everything was fine. I also called my MB service department and got basically a shrug of the shoulders, which I guess is understandable but a little disconcerting.
Old Apr 1, 2025 | 10:16 AM
Glad it worked fine. It may just be a weirdness or even power glitch while plugging in to your home charger. Are you using the MB-provided EVBox charger, or something else?
Old Apr 1, 2025 | 10:26 AM
I have a ChargePoint box, which I installed before I learned that MB would give you one for free/cheap with an EV purchase. I am really loving this car.
