Lagging / Glitchy Navigation?
Occasionally, when using Nav or Apple Car play, the entire MBUX system is "laggy" or "glitches" where it only refreshes maybe every 1/2 a second instead of a continuous, smooth refresh. I cannot figure out why this is happening. Once it starts lagging on a trip, it does not smooth out ever, even if I disconnect my phone, or even if I turn off the system and turn it back on.
I've asked my local dealer--they seem pretty clueless as it is such a new car and say that it is not a reported issue that they know about.
My "workaround" is to start the car, wait until everything loads up, log-in, wait a few extra seconds for everything to properly load, and then start using it to navigate. My feeling is that I am asking the system to do too much at startup and therefore it lags and cannot catch up.
Has anybody else had this issue?
I also had an issue briefly with wireless charging, but that seems to have resolved itself.
When I turn off the car and restart it (by opening the door and closing it, even in the same location, the glitch often goes away. However, when I just delete the destination and reinput it without restarting the car, the glitch persists. It's almost like there isn't enough memory or something.
I have noticed though that if it starts out very smooth, if you go into the settings and change sound settings, or ambient light settings, or any other setting in the MBUX system, you can make it glitchy.
If you hold your finger on the screen while it is being glitchy it seems to smooth out when your finger is touching the touchscreen but obviously that is not a sustainable solution.
I was hoping it was my iPhone 13 Pro that was the problem but now that I have the iPhone 14 Pro the problem still persists.
If at the dealer, did your dealer know about it and do it automatically or did you have to ask them to update it for you?
I specifically asked him to check with the technicians when I brought the car in for a charging issue earlier this month (Oct 2022) to make sure I am on the newest software and he told me I was. The SAM module and the AC module whatever that means was updated but I still had the same old Version number. Based on your post, today, I brought this up with my service advisor who told me there was some sort of miscommunication and that they could update me to the newest version (car has to be brought in as you say).
I am going to bring it into the dealer for them to update the software. I'll update everybody if it helps with the lag.
Fun being the first but also annoying AF to find these issues and not have a fix for months!
INTERNAL SOFTWARE ERROR IN MBUX
VERIFIED DELAY IN MAP MOVEMENT WHEN USING APPLE CAR
PLAY.CONNECTED SDS AND PERFORMED SHORT TEST, FOUND
STORED FAULTS IN MBUX INCLUDING; B21A100 An internal control unit
reset was performed. FOLLOWED GUIDED TEST AND DUE TO
CUSTOMER COMPLAINT WITH MBUX FUNCTIONALITY, UPDATE
MBUX CONTROL UNIT SOFTWARE. VERIFIED NEW SOFTWARE
AVAILABLE, PERFORMED UPDATE. AFTER UPDATE CLEARED FAULT
MEMORY AND VERIFIED NO FAULTS RETURN AND APPLE CAR PLAY
IS FUNCTIONING PROPERLY.
I had asked my dealer to update my software a few weeks prior but he said there was a miscommunication and his tech had told him that I had the latest version, which was obviously incorrect. Push your dealer to give you the update if you have the same issues!
I did experience under CruiseControl the sudden braking at certain curves, but with the help from this board, quickly ironed that out.
I can truthfully say I am completely satisfied with my car in every regard.
Any thoughts?
