Map modes
Map modes
Is there an easy way to toggle between map modes? I see the 2D, 3D on the screen but have not found the way to change from satellite mode to the normal map screen or vice versa. The manual’s recommended technique of finding within the EQ menu did not work.
2022 EQS 580 4matic, 2022 GLS 450
After much time on the phone with Mercedes and getting no where with this I finally figured out that the Owner's Manual is wrong (as is MB customer support).
The 2D/3D tab does not work. You have to touch the EQ tab upper left of NAV screen, then the settings wheel tab lower far right, then VIEW and turn off the Satellite View button.
You can also get "Hey Mercedes" to do it if you say the right words but I forgot what worked.
Let us know if you find out.
This worked for me. For some reason, I missed the cogwheel the first time around. “Hey Mercedes turn on satellite map. Hey Mercedes turn off satellite map.” Seemed to work for me as well.
