Charging Port Opens Randomly
When approaching my car in the garage, I've found that the charge port door is open. (The self presenting handles come out, but the charge port door is already open.).
At first, I thought I might not have been clicking in the door completely after a charging session, but this has happened 3x already. If it happens again, I'm going to take the vehicle back to the dealer to have it examined and/or repaired.
Any guidance from the forum would be appreciated. Thanks.
My car has now done this several times. I'm going to make an appt to take it to the dealership for diagnosis/repair.
If anyone has any other ideas, please share them. Thanks.
- the Charge Cap Open warning comes on ALL the time and it is not open.
- Charge cap opens itself... seems only when car is off
- Low tire warning comes on all the time but PSI is in range (also will display +/-3 PSI within like 5 minutes)
- Got a warning that Starter Battery is Critical
- Door handles don't always come out
- Car will randomly unlock itself while I'm in the store
- Car randomly won't be recognized at charging stations
- Also it will go nuts like I'm about to hit something right in the middle of the hood, but nothing is there.
- The low beam lights have a big dark spot on the driver side that kind of catches your eye as you drive at night
Super Buyer's Remorse with this car and only 3k miles.
P.S. most of the other problems just started in the last week or two. I wonder if there was a software update.
They will not come out if the key has gone in to sleep mode. They will not automatically come out as you approach the car and they will not come out if you touch the handle with the fob in sleep mode.
If your key has been Idle for too long they will enter sleep mode. If you double press the lock button it will also enter sleep mode.
Have the handles ever failed to come out after you pressed the unlock button on the key fob?
