How to specify USB C
I also have a dash cam.
How do I specify which USB C is for the dashcam vs. music?
Right now, the car is totally confused. When I play media, it brings up the dashcam recording!
It will show up as a different folder. When you select media a drop down of usb attached media (including the camera) will show up. Once you select it all your music files will be there. It is plug and play. Its a little wonky at first but once you figure it out its fairly straight forward. Note you can only search by voice in that particular folder (your flash drive). High resolution 96/24 and over files sound superb!
