EQS EQS (V297) sedan
Mercedes Me Connect Store USA
Old 06-15-2022 | 04:26 PM
  #76
superswiss's Avatar
2019 C63CS
Since they just rolled out the store 2 days ago I don't expect it to run smoothly. Probably a good idea to wait a while and let them stabilize it. I'm sure the support staff has probably barely been trained and they have no actual experience troubleshooting it yet.
Old 06-15-2022 | 04:28 PM
  #77
david_sd's Avatar
2021 GLA 250
Since they just rolled out the store 2 days ago I don't expect it to run smoothly. Probably a good idea to wait a while and let them stabilize it. I'm sure the support staff has probably barely been trained and they have no actual experience troubleshoot it yet.
I paid $550. I expect it to run smoothly.
Old 06-15-2022 | 04:34 PM
  #78
superswiss's Avatar
2019 C63CS
Well, you can always request a refund or dispute the charge with your bank.
Old 06-15-2022 | 05:04 PM
  #79
Eaton's Avatar
I think the main pain point with them offering navigation OTA is the cell/data download speed that varies greatly from one place to another. The maps are also multi-gigabyte downloads, which doesn't help.
Old 06-15-2022 | 05:11 PM
  #80
superswiss's Avatar
2019 C63CS
That's an interesting point I didn't consider. The car obviously has to download the map data first since it doesn't come from the factory. A full map update is something like 18GB for the entire USA + Canada + Mexico, about 15GB for just the USA. The OTA updates only install your home region and the other regions have to be downloaded manually, specifically because it's a lot of data. I'm curious if this only installs the map for you home region or if it's downloading the entire USA+. If the latter then yes that's gonna take a while.
Old 06-15-2022 | 05:14 PM
  #81
Eaton's Avatar
To those still waiting. maybe try going to this page to see if it will let you install map data over USB:
https://www.me.mercedes-benz.com/pas...ap-update.html
Old 06-15-2022 | 05:25 PM
  #82
david_sd's Avatar
2021 GLA 250
That's an interesting point I didn't consider. The car obviously has to download the map data first since it doesn't come from the factory. A full map update is something like 18GB for the entire USA + Canada + Mexico, about 15GB for just the USA. The OTA updates only install your home region and the other regions have to be downloaded manually, specifically because it's a lot of data. I'm curious if this only installs the map for you home region of if it's downloading the entire USA+. If the latter then yes that's gonna take a while.
Does it download the map while the car is not in use though? If not we would have to drive around for a while. I live in a big city and T-Mobile is pretty good here.
Old 06-15-2022 | 05:26 PM
  #83
Eaton's Avatar
My maps have updated automatically without the car being in use.
  #84
david_sd's Avatar
2021 GLA 250
Old 06-15-2022 | 05:36 PM
  #85
superswiss's Avatar
2019 C63CS
Does it download the map while the car is not in use though?.
Nope, since the electronics are powered by the 12V battery all downloads and updates are paused if the car is not in use. This is partly why I generally update the maps manually. It takes about 20 minutes from the SD card and the ignition needs to be on. OTA updates are downloaded in the background while driving and then installed, so generally one doesn't notice. I thought I read a disclaimer on the store website, too, that activation only takes place when the car is in use.
Old 06-15-2022 | 05:38 PM
  #86
Eaton's Avatar
If you do it over USB and turn off the car, it does pause it.
But OTA, I've had it happen with the car fully off and the app notified me.
Old 06-15-2022 | 05:39 PM
  #87
Ed1z's Avatar
2020 GLC350e, 2017 B250e, 2005 CLK500
I can hit a golf ball to the cell tower…..I’m at 58 hours since purchase……MB didn’t test this download to see how long it would take?
and then maybe……State the approximate time on the page where you purchase it.
if they thought they couldn’t handle the volume then they should have throttled the sales of Nav.
To just leave everyone in this position is abjectly unprofessional.
Old 06-15-2022 | 05:45 PM
  #88
superswiss's Avatar
2019 C63CS
The app notification is only letting you know that there is an update as far as I know. I know that the OTA updates pause when the car is parked, because I've watched it resume the next day by leaving the update screen up. The maps are not updated until you get a notification in the car. Maybe being electric it's different in the EQS, but I doubt it since the 12V battery is currently only recharged while the car is in use, so they would not let the update run and potentially drain the 12V battery.
Old 06-15-2022 | 05:53 PM
  #89
Old Dawg's Avatar
EQS 450+
Originally Posted by Got AMG
Here is the link for the new Mercedes Me Connect Store.
https://shop.mbusa.com/en-us/connect/
FYI for everyone wanting to purchase dashcam. It will be available to purchase at the end of June.
I finally got into the store and Dashcam is not there....however what is there is all the "services" that came with the car that are going to expire in a year and will be available for repurchase for various prices. The worst one is the Mercedes Me Charge which is going to cost $80 to renew when it expires in 2024. Needless to say I will be working on alternatives between now and expiration dates.
Old 06-15-2022 | 06:00 PM
  #90
Ed1z's Avatar
Old 06-15-2022 | 06:05 PM
  #91
superswiss's Avatar
2019 C63CS
Originally Posted by Ed1z
This can be pretty much only the case for simple activations where no software or data needs to be downloaded to the car first. For example live traffic etc. Those are just a license activation. But as said above, if you purchase navigation it needs to download the map data first and that's a big download. Ain't gonna happen in 2 minutes.
Old 06-15-2022 | 06:06 PM
  #92
david_sd's Avatar
2021 GLA 250
I turned it on and off several times after buying the navigation. It didn’t work and I don’t have the navigation button in the menu. The person on the phone yesterday said that they can’t see this service being activated in my account so it must be an internal issue.
Old 06-15-2022 | 07:12 PM
  #93
c4004matic's Avatar
17 E43; 21 GLS580
There is really nothing there for new owners at least for the first year. I was hoping for something more.
Old 06-15-2022 | 08:14 PM
  #94
bespokeensemble's Avatar
AMG GLB35
Please do update if/when your Nav is ready!
david_sd (06-15-2022)
Old 06-16-2022 | 03:37 AM
  #95
RocksB's Avatar
2019 A220 4MATIC
Just curious but not suggested, have you tried to look it up through the Dealer Mode, and see if the option to activate it is there?
Old 06-16-2022 | 07:07 AM
  #96
Ed1z's Avatar
so….what does all this mean?
Old 06-16-2022 | 08:03 AM
  #97
RocksB's Avatar
2019 A220 4MATIC
This is my screen.
Old 06-16-2022 | 01:13 PM
  #98
AMG GLB35
Anyone got their Nav working yet?
Old 06-16-2022 | 01:21 PM
  #99
Ed1z's Avatar
Nope….78 hours and waiting.
also……the store servers have now crashed!
just got off the phone with them.
Old 06-16-2022 | 05:05 PM
  #100
david_sd's Avatar
2021 GLA 250
Nope
Quick Reply: Mercedes Me Connect Store USA
