EQS EQS (V297) sedan
Hood Open Warning Light
Old Feb 15, 2023 | 05:52 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
We've only had the car for a couple days, and got our first warning light. When accelerating quickly, the hood open warning light comes on, with an audible warning sound that continues to go off until the car is shut off. Anyone had this? I'm assuming just a touchy sensor.
Old Feb 15, 2023 | 07:56 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Have you opened the hood and then closed vigorously to see if it is locked closed properly?
Old Feb 15, 2023 | 08:31 AM
nath_h's Avatar
Not yet. My wife doesn't want me messing with it, but I'll convince her to let me give it a try. Perhaps the hood alignment is slightly off, or something. I already researched how to open the supposed sealed/only accessible by technician front hood.
Old Feb 15, 2023 | 09:01 AM
rbourge's Avatar
2022 EQS 580 4matic, 2022 GLS 450
It's not really sealed, it opens like a regular hood using a slightly hidden latch. It would certainly be prudent to open the hood and cycle the switch by hand a few times before giving a new car up to the shop for a day or two. As has been stated a good solid hood closing might do the trick.
Old Feb 15, 2023 | 09:08 AM
The lever is under the steering column to the left just like many other MB’s. The tiny cover over the lever might have a screw holding it on but some are missing. If you just open and close the hood there is no danger. Everything under the hood electrical is covered or insulated and not near the latch.
If for no other reason I looked under the hood to find the red positive 12v battery post in case it ever needed to be charged on the road to get the EQS started.
Old Feb 15, 2023 | 07:01 PM
nath_h's Avatar
Okay, so maybe the problem has been solved. My wife called me on Facetime from work, and I talked her through how to open it. There is apparently not a traditional latch like on a conventional car, but she closed the hood firmly and reports that it seemed more well set. She took it for a quick (literally) test drive, and no warning light. So hopefully when she drives home tonight the problem is solved. Would be great if it were this simple.
Old Mar 29, 2023 | 09:55 AM
MB_Drive's Avatar
EQS
Hi! I’ve been having the same issue with my EQS and was wondering if just opening and closing the hood resolved the problem or if you had to take in for service? Thanks!
Old Mar 29, 2023 | 10:09 AM
AppleFan1's Avatar
2025 EQS580
I think it is that simple. When I drove the car home for the first time almost a year ago, I had that same warning. The GM stopped by on his way home and he opened the hood and then closed it vigorously. Bingo! Problem solved. He noticed when he first got here that the hood was not quite aligned properly on the left side when looking at it from the front of the car. So he knew what the problem was was and opening and closing it hard did the trick.
Old Mar 29, 2023 | 01:24 PM
MB_Drive's Avatar
EQS
Oh ok, good to know. Thanks so much! Glad it’ll be an easy fix.
Old Mar 30, 2023 | 08:14 AM
nath_h's Avatar
Yup, that simple. Based on my previous over complicated car experience, I thought it would be a sensor or something, but it just needed a firm closing.
Old Mar 30, 2023 | 04:35 PM
c4004matic's Avatar
17 E43; 21 GLS580
Surely the hood was opened during processing, and one of the latches is not fully engaded. Open the hood and give it a good drop. The easiest way to see if it's fully closed is to look where the rear portion of the wheel arch and hood align. They should be perfectly flush and straight on both sides. If the are not, there's a latch still loose.
Old May 8, 2023 | 05:58 PM
AMGenema's Avatar
2003 SL55 AMG
Mine worked fine until I just put an ecu upgrade in. Now when I accelerate hard the light comes on until I slow down the it shuts off. Any idea where the adjust ment for the switch is? Because I’m not giving up accelerating. 😬
