EQS EQS (V297) sedan
How to stream video in your EQS
Old Jul 31, 2023 | 06:40 PM
SirNH's Avatar
EQS 450+
I made a little video about this device from a company named Carlinkit. The device is called the T-Box Plus. Using wired CarPlay it turns your EQS touchscreen into an Android tablet. This cost me about $190.
I installed a standard T-Mobile cellphone SIM to get unlimited streaming, but you can connect the device to your phone's or car's hotspot, too. I think it may be possible to even turn the device into a hotspot if you installed a SIM, I haven't tried that, yet.
Even though it has the Google Play Store, most of the streaming services on the store are not compatible with the device, but a quick jump to APKMirror.com on the built-in chrome browser will let you download versions which work just fine. The only service I couldn't find, so far, is Apple TV+.
Check out my video here:
Old Jul 31, 2023 | 08:41 PM
Vernium's Avatar
EQS 450+
Why would you post this? Would I have ever streamed Karate Kid on my EQS? Probably not. But now I have to, you have tempted my inner geek. Was this intended as some kind of incentive for using a slow charger?
Must not order until I sort out tracker, immobiliser, dashcam.
Must not order until I sort out tracker.
Must not... aaarrrggh!
Old Jul 31, 2023 | 11:26 PM
bgrewal's Avatar
EQS580
Is there a way to get it to work with passenger screen. That way they can watch and listen with headphones without disturbing the driver? I know I can use the built in browser to stream but the browser takes. Away the screen real estate. There is no full screen mode.
Old Aug 1, 2023 | 12:24 AM
SirNH's Avatar
EQS 450+
I just tried and there's no way to send CarPlay to the passenger screen. The best you can do is use bluetooth headphones to not distract the driver with the audio while you watch the video on the center display.
Old Aug 1, 2023 | 01:29 PM
nosnoop's Avatar
535
I guess when the T-Box is connected, your phone's wireless carplay would no longer work?
Old Aug 1, 2023 | 04:15 PM
SirNH's Avatar
EQS 450+
They don't work directly in MBUX but you can then use the T-Box to host a wireless carplay or android auto session, so it's an extra hop.
Old Dec 24, 2023 | 01:50 PM
genechen22's Avatar
EQS 580
Carlinkit Ambiant does not work on 2022 EQS old or new MBUX software. Both versions came up with blank screen for Carplay. Not sure if the older versions of the Carlinkit works but for sure won't work with newer process and ambient version.
Old Jan 9, 2024 | 04:46 PM
thebigkat82's Avatar
EQS
I am getting this screen
Old Jan 9, 2024 | 04:51 PM
genechen22's Avatar
EQS 580
Exactly what I got!
I had contacted suppport to give me their burning software and did a wipe partitions and then loaded a new image. Then when you plug it into the car, it will come up with a prompt for you to calibrate screen resolution.
This fixed the issues at hand but when you connect a iphone, you'll get the blank screen for carplay from iphone.
Old Jan 9, 2024 | 04:52 PM
EQS
forgive me as I am dense
I have a 2023 EQS SUV
Apple Iphone and this unit I bought because your video is awesome
When I plug the unit into my car, carplay is blank
Old Jan 9, 2024 | 04:54 PM
EQS
Exactly what I got!
so if I am understanding you correctly, with the proper software update you were able to get this device to work but it messed up your iphone carplay when you plug in your iphone? Personally I don't care about my iphone plug in carplay as I never use carplay with my iphone
Old Jan 9, 2024 | 04:57 PM
EQEBlue's Avatar
EQE 350 4matic
Why not stream from browser? Genuinely curious.
Old Jan 9, 2024 | 05:06 PM
genechen22's Avatar
EQS 580
Carplay is fine if you don't use the Android AI box. It's blank when you connect iphone to Android AI Box.
Old Jan 9, 2024 | 05:08 PM
EQS
So is your current setup now working? I put an email out to their support
Old Jan 9, 2024 | 06:57 PM
genechen22's Avatar
EQS 580
Work perfectly fine, minus apple carplay thru the streaming box. That gets a blank screen.
Old Jan 9, 2024 | 07:49 PM
EQS
do you still have the file they sent you to update the box
Old Jan 9, 2024 | 09:59 PM
SirNH's Avatar
EQS 450+
The browser has limited streaming capability and it doesn't support streams that require content protection - so no NetFlix.
Old Jan 9, 2024 | 10:00 PM
SirNH's Avatar
EQS 450+
I never bothered to try connecting my phone to the AI Box, as I only use it when I am just sitting in my car waiting around. In that case, I can just pick up my phone if I need it.
Old Jan 10, 2024 | 10:31 AM
EQS
I got an email from their support, will try that later today and update you all1. Prepare a TF/micro sd card not larger than 256GB (hereinafter referred to as TF card);
2. Change the name of the downloaded firmware to update.zip and copy it to the TF card;
3. Insert the TF card into the TF card slot of the product in the correct direction.
4. Upgrade for about 10 minutes, the model number light will flash alternately, do not power off/unplug the box in the middle;
https://drive.google.com/file/d/18VR...ew?usp=sharing
Old Jan 10, 2024 | 06:34 PM
EQS
I tried this method todayBurning Toolhttps://drive.google.com/file/d/1f46a31YZR8d_Kmyp3l7CWcrQXO-zCYiD
Video Tutorial
6125138 choose ufs
https://drive.google.com/drive/folde...Me?usp=sharing
I am getting a SaharaFail server message, did you experience that?
Old Jan 10, 2024 | 09:31 PM
genechen22's Avatar
EQS 580
I did not receive any errors, but I also have different firmware options.
I have the 6225 and first used rawprogram0_WIPE_PARTITIONS.xml_bak.xml
Then loaded the rawprogram01 or something.
Finally updated using the microSD with the latest image.
Old Jan 10, 2024 | 10:54 PM
EQS
can't get the update.zip to flash to the unit
tried to do the firmware update, getting the Sahara failure
total waste of time with their customer service, I even showed them the youtube video posted here and they aren't helpful
Old Jan 11, 2024 | 08:14 AM
EQS
I have totally struck out with this company.... you should get a few of these boxes and have them "set up" to work for the EQS and sell them on the forum. I sure as heck would rather pay for one ready to go for the car, I've spent too much time on this to be struck out
Old Jan 11, 2024 | 08:54 AM
EQS
so I have given up with CarLinkIt. I did find
https://trymagicbox.com/products/the-magic-box-series-2
Called them and they said it does work for the EQS, fingers crossed and will update everyone
