EQS EQS (V297) sedan
Climate settings not working
Old Nov 18, 2023 | 03:02 PM
AppleFan1's Avatar
2025 EQS580
After the major MBUX update several weeks ago, the climate menu and temperature settings are inoperable. At first, the temperature setting was not working at times. I thought it fixed itself but now it’s stuck at 75 degrees no matter what I try. Additionally, the only screen I can get when I press the climate menu is the heat or AC option no matter what I try. For example, I cannot get to the screen which shows the ECO setting. I brought it to the dealer a couple days ago and the head mechanic told me that he will try to find out what’s going on. Any thoughts from you folks?
Old Nov 30, 2023 | 07:23 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Did this get sorted out? Just curious. Sounds like a software issue.
Old Nov 30, 2023 | 03:25 PM
MB37's Avatar
23' EQS AMG
Sounds like it needs to have the 12v unplugged, the head unit unplugged from the main battery, a reconnection, and a reboot. If that doesn't clear it, a reflash of the head unit. If that still doesn't work, and you are experiencing other glitchy functions, a new head unit is needed.
Old Nov 30, 2023 | 06:37 PM
AppleFan1's Avatar
2025 EQS580
Yes it did, thanks. The head mechanic had to do some recoding whatever that means. Now I can change the temperature settings when not on energy saving options.
However, I still only see one screen when I touch climate control. The mechanic said that’s just the way it is since I can use the energy saving options by touching the EQ symbol, then range to choose which energy saving options to choose instead of ECO + on a climate screen that I no longer see.
Does this make sense?
