EQS EQS (V297) sedan
Configuration Coding ideas
Old Jan 8, 2024 | 09:33 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
I’m going to buy a coding session to configure some more functionality.
Wanted to hear from those who have done this, what features should I code.
Here is my preliminary list:
  1. Digital Light System with Projection
  2. Set default drive mode to Individual
  3. Suspension height change control
  4. Rear light bar always on (Rear DRL)
  5. Front light bar on with DRL
  6. DRL menu in MBUX (if available)
Any other ideas?
Old Jan 8, 2024 | 10:02 PM
LAZARU5's Avatar
2025 E53 Hybrid
I had the default drive mode changed to Individual and I love it. Making this change effectively allows you to reconfigure the default to whatever makes sense for a particular situation. For example, now in the Winter when range is in the tank, I like to keep the default in Eco.
I also had the suspension lowered. This turned out to be a little more complicated and I will create a separate thread to describe what was involved.
Old Jan 8, 2024 | 10:09 PM
Thanks. I’m not really interested in lowering it. I’d be more interested in a button to raise it when I think it will scrape. Like I used to have in the 2018 E63S
Old Jan 9, 2024 | 07:38 AM
Tjdehya's Avatar
2023 AMG EQS
#4 sounds like a terrible idea. The whole point of the third brake light is a higher point for drivers to see when you hit the brakes, if it’s always on the you are defeating the purpose.
Is it possible to have two levels of intensity on the rear brake light bar? Low intensity as you “rear DRL” and high intensity when you hit the brakes?
Old Jan 9, 2024 | 11:06 AM
the light bar is not the third brake light. The third brake light is higher up.
Old Jan 9, 2024 | 09:07 PM
avalys's Avatar
2023 EQS580
Can you turn on the AMG drive mode displays? I think they get more detailed performance information about the electric motors (current, temperature, etc.)
Old Jan 10, 2024 | 07:05 AM
tuffcalc's Avatar
C63
Any other ideas?
Hi there - just wondering where you booked your coding session? Thank you!
Old Jan 10, 2024 | 01:15 PM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
It would be interesting if your coder has any comment about whether the turn signal volume can be changed.
Old Jan 10, 2024 | 05:29 PM
The answer will be no. That is not a regional setting. Basically the coding just enables you to set a feature to the way it is done somewhere else in the world. So for instance in the USA there is no rear DRL required by the DOT so rear DRL is coded to be off. In Europe, cars are required to have a rear DRL so in Europe the rear DRL is coded on. What coding does is enable you to create a Hybrid of these different default settings to suit your personal preferences. e.g. European style matrix high beams, rear DRL, while other settings maintain US specs.
Old Jan 11, 2024 | 04:05 AM
ScottC2's Avatar
Thank you for the education on coding, stealth.pilot! I had no idea...
Old Feb 7, 2024 | 04:24 PM
ivanvach's Avatar
EQS 450 4 matic sedan, Mercedes 550S
How to get in touch with a "coder"
@stealth.pilot
Few questions here
1. How to get in touch with a "coder" ?
2. Are the "coders" certified by any means ? What if he messes up the whole car ?
3. I'm very interested in a feature that is available in Europe but not in the USA. It is "self parking in a garage" on private property (not public garages). The driver will park himself the first time and the car will remember it and repeat it thereafter. Is it possible this feature to be added by a "coder"
Thanks,
Old Feb 8, 2024 | 03:38 AM
LuisGese's Avatar
Mercedes W164 320 Cdi 4Matic 224hp
Originally Posted by ivanvach
@stealth.pilot
Few questions here
Thanks,
I have that option in Portugal, very slow and you have to be inspire the car
Old Feb 8, 2024 | 09:43 AM
Would it be possible to share a video of that? I would love to see it in action. We don't have this In the USA.
Old Feb 8, 2024 | 09:59 AM
ScottC2's Avatar
This is not exactly a video. It's an animation. Nevertheless, it might be informative for you even if you ignore the audio, which is in Swedish. Perhaps an English version exists somewhere, but I haven't found it yet.
https://www.mercedes-benz.se/passeng...en-memory-park
Basically, it says record the maneuver you want to perform and then the car will be able to repeat it. Think Excel macro...
P.S. I don't have this capability on my car, since I did not buy the remote parking package, which is a prerequisite.
Old Feb 8, 2024 | 10:09 AM
@stealth.pilot
Few questions here
Search on this board there are several. You can contact them using the contact info on their websites.
RJ Automotive - very well regarded on these boards. UK based so they speak English and offer remote coding. However they are a bit pricey.
https://mbworld.org/forums/w213-amg/...fit-offer.html
Elebest
https://mbworld.org/forums/eqs/880357-usa-eqs-297-ihc-activation-coding-enet-cable.html
BenzNinja - offers a DIY solution if you are up for that
https://mbworld.org/forums/c450-c43-...a-s-n-1-a.html
Not certified since MB doesn't encourage this. I don't think they would mess up the whole car. The worst case is they accidentally corrupt a file. In this scenario they could reupload the backup, or you could take your car to a dealership for them to flash it back to stock settings. But I have never had this issue, not even when I did it myself on my BMW.
No idea. Depends on whether the car has all the hardware for this feature or not. Check with the coders. I usually find that all self parking features are slower than driver parking so I prefer to park myself.
Thanks,
See answers above:
Old Feb 8, 2024 | 10:16 AM
Interesting. I wonder if it can also park in reverse?
This is another solution to this type of thing.
https://www.motortrend.com/events/bm...logy-ces-2024/
Old Feb 8, 2024 | 10:34 AM
Diesel Benz's Avatar
British English:
https://www.mercedes-benz.co.uk/pass...parking-assist
Old Feb 8, 2024 | 10:43 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
I would love to have cornering lights turned on but I understand that they may not even exist. This I find very strange as the lower tech lights on our 2019 had that feature. I pinged RJ Automotive that turned on the intelligent high beams but haven't heard anything back yet.
Old Feb 8, 2024 | 02:14 PM
Cornering lights are part of the main light unit that is capable of adjusting the light pattern in several ways. Cornering lights being just one pattern as explained in the US manual on page 150. For quite a while there has not been any specific bulb for this feature (fog lights or a cornering light bulb within the main light unit).
EDIT: sorry, I was referring to the W223 manual but the same content must be part of the EQS manual too.
Old Feb 8, 2024 | 04:33 PM
lkfoster's Avatar
I see that in the manual also, just that there's nothing but a black hole when turning at low speeds. Nothing at all like our 2019 E-class. There pivoting headlight beams don't go nearly wide enough and the wide A pillars don't help.
Old Feb 9, 2024 | 12:40 AM
OK, I need to pay attention to this detail when next time driving the car when it is dark.
Does the 2019 E-class have multi-beam lights or the basic LEDs?
Old Feb 9, 2024 | 01:59 AM
MB37's Avatar
23' EQS AMG
Somebody let me know when MB will allow us to project images on the road in the USA. Also, the rain drops and AMG animation is getting old. I wish there were more. I'll pay. Also, add more exterior sounds or customizable. Wish list.
Old Feb 9, 2024 | 11:06 AM
lkfoster's Avatar
When changing lanes using a turn signal with cruise control the lane change projection shows. It has to be turned on in settings. It's not real bright nor does last very long, all in all not that impressive. I haven't seen any warning projections in the last 7k miles.
I don't recall what Merc calls the lights on our E53 but they are multi-LED with similar start-up patterns and intelligent high beams if activated to the EQs.
Old Feb 9, 2024 | 09:12 PM
EleBest's Avatar
SPONSOR
E200 2010, G63 2018, E53s 2019, EQS53 Touring 2021, S500 2022, A200 2023
Memory Parking Assist in EQE for your info:
EQE Memory Parking Assist
Old Feb 11, 2024 | 11:40 PM
Look what elebest coded on my US spec car.
