EQS EQS (V297) sedan
Warning
Old Jan 11, 2024 | 10:51 PM
AppleFan1's Avatar
2025 EQS580
Warning
I had the dealer install the E445 software update several months ago. My thinking was that the newer the better. I was so wrong. I warn you NOT to install this update. It’s given me nothing but trouble. The main issue has been the climate control system. I go through stages when I cannot adjust the temperature. Even though it may say 72 for example, only rather cold air comes out. I annoy change the setting because it goes right back to 72. It’s so frustrating. Then there are periods when it works before it goes back to the crapper.
I think I discovered a solution today. If I turn on the windshield defroster, warm/hot air blows out. I turn it back to off and the temperature setting then works. Very weird! With the E445 it does not show an option to set the system to auto preconditioning of the main battery as I go to charge the battery.
Old Jan 12, 2024 | 04:33 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Originally Posted by AppleFan1
.. there are periods when it works before it goes back to the crapper.
Maybe there's a hardware issue that's making the software act funny. Just a stab in the dark. Might as well upgrade to E555 (or whatever it'll be called -- not something like 24.5 that's for sure) when it comes out anyways.
Old Jan 12, 2024 | 05:20 AM
Tuituibang's Avatar
EQS 450+
What are the main differences between E445 and E330 besides the glitch you experienced? Does it offer anything new?
Old Jan 12, 2024 | 06:23 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Thanks for the warning. Ours is scheduled for the update soon. It's tempting to leave well enough alone. A pet peeve of mine is software engineers continually 'enhancing' their product, which usually requires a learning curve and often makes things worse.
Old Jan 12, 2024 | 08:03 AM
AppleFan1's Avatar
2025 EQS580
I think it offers less, if anything. I already mentioned that as opposed to the E330, the climate menu has less options. For example, it does not offer the screen which shows the option for auto preconditioning of the main battery.
Old Jan 14, 2024 | 08:29 PM
hlothery's Avatar
Veteran: Army
I have been very reluctant to upgrade the system for this very reason. If it ain't broke......
