EQS V297 USA Spec Hidden Features: Dynamic Low Beam, Partial High Beam,
Hi All EQS/EQE (V297/V295) owners (USA Spec with Digital Light):
Now you can fully activate your hidden features listed below by our remote coding service (Windows laptop+enet cable)
https://wa.me/6597335000
1. Cornering light function
The cornering light improves the illumination of the road over a wide angle in the turning direc-tion, enabling better visibility on tight curves, for example. It can be activated only when the low beam is switched on.
The function is active in the following cases:
At speeds below 25 mph (40 km/h) when the turn signal light is switched on or the steering wheel is turned
At speeds between 25 mph (40 km/h) and 43 mph (70 km/h) and when the steering wheel is turned
2. Roundabout and intersection function: the cornering light will be activated on both sides based on an evaluation of the vehicle's current navigation position. It will remain active until after the vehicle has left the roundabout or the intersection.
3. Highway mode function
Highway mode increases the range and brightness of the cone of light, enabling better visibility.
The function will be active if a freeway journey is detected by means of:
The vehicle's speed
The multifunction camera
The navigation system
The function is not active in the following cases:
• at speeds below 50 mph (80 km/h)
4. Enhanced fog light function
The enhanced fog light function reduces self-blinding and improves the illumination of the edge of the road.
The function is automatically activated under the following conditions:
• At speeds below 43 mph (70 km/h) and when the rear fog light is switched on.
5. ULTRA RANGE Highbeam increases the brightness of the cone of light to the legally permitted maximum.Partial high beam does not include other road users in the high beam area. It does not dazzle them but enables full high-beam illumination for the driver apart from the excluded vehicles. Highly reflective signs are also illuminated with reduced brightness.
At speeds below 16 mph (25 km/h) or when there is sufficient street lighting:
• Partial high beam and high beam will be switched off automatically.
At speeds greater than 19 mph (30 km/h):
If no other road users are detected, high beam will switch on automatically.
If other road users are detected, partial high beam will switch on automatically.
at speeds below 25 mph (40 km /h):
• The ULTRA RANGE Highbeam will switch off automatically.
Here in Texas, I'll pay good money for anyone that can invent smart mirrors. I want the kind of mirror that auto aims at drivers driving with high beam coming from front or rear. Give them a taste of their own bright lights.
Haha, you're gona pay zero, if all USA cars get these advanced lighting features.
