EQS EQS (V297) sedan
12 VOLT ACCESSORY BATTERY???
Old Dec 3, 2024 | 09:33 PM
tooold2race's Avatar
EQS Sedan
This is my first problem after about 18 months of ownership (leased) of our EQS 450+ sedan. The 'phone app', MY MERCEDES, displayed a RED triangle and the text 'battery critical'. Clicking on that leads to a message about the 12 volt battery being critically low. Note that there was no warning or display on the cars instrument panel. Everything seemed to work just fine. Well after a couple of weeks with the warning on my phone app, I took it to the dealer. No problemo..... they replaced the 12 volt battery and everything was / is fine.... just like it always was, EXCEPT the display with the warning is still on my phone app. The dealer said it would clear itself in a few days. It hasn't. Calling MY MERCEDES, which was a challenge, I was told it was a dealer problem. Going back to the dealer, they said it's a problem with the app.
Any thoughts??? The car operates fine but my wife always asks if it's going to strand her someplace.
Old Dec 4, 2024 | 01:35 AM
Diesel Benz's Avatar
What does the app say about the 12 V battery now at the services page?
It could be the car has not sent all status data to the MB Me server, perhaps only sending the critical battery alert but not any subsequent clear message. It could be the server confused, not clearing the info towards the app. It could be the app getting up-to-date info but not clearing the alert. You could play with the car remotely, change charging settings, set heating on/off to make the car update status data to the server. You could delete all temporary data from the app, perhaps reinstall too. Unfortunately no way to reset the MB Me server.
Old Dec 4, 2024 | 03:44 PM
Radman991's Avatar
2005 SL 500. 2015 S550. 2016 GLE400 2018 S560
I had a similar problem with the 12 volt battery and getting the critical low warning. Like you the dealer replaced the battery and ever since all is well, the warning cleared and occasionally I get a partially charged warning if I let the car sit unused for a while. It self charges itself within a day or two. Service adviser said to put trickle charger on it for extended downtime periods.
Old Dec 5, 2024 | 03:55 PM
EQEBlue's Avatar
EQE 350 4matic
Something to note here is that the HV battery does not maintain the LV battery below 15%; why? I dunno.
If your HV state of charge is over 20%, the DC-DC bus will maintain LV (12V and 40V) systems. The app message is triggered from the vehicle if the vehicle hasn't been driven for an extended period of time. Also, I hate MBUSA's practice of recommending 12V trickle chargers to MB workshops, especially given entering service mode does not deactivate the DC-DC bus and ruins the LV maintenance system in EQ products.
Old Dec 5, 2024 | 04:45 PM
hlothery's Avatar
Veteran: Army
When I am cleaning the interior or otherwise will have the doors open for a long time (like when I take it in for service), I always reach up and turn off the main interior lights to protect my 12V battery as much as possible. I have received no warnings. Maybe this has helped?
Old Dec 5, 2024 | 04:46 PM
Radman991's Avatar
Although being told by two different service advisors from 2 different dealers to put it on a trickle charger for prolonged periods, I have been hesitant to do so. I figured if the car will maintain it on its own why add another level of complexity. When my car is in downtime I am 1400 miles away and obviously couldn’t do anything if the charger went on the fritz.
Since getting a replacement 12 v battery, the car has maintained its state of charge without me doing anything. I suspect the original 12 v battery may have failed because the car sat at the Baltimore VPC for 4 months before they released it to the dealer.
Old Dec 5, 2024 | 04:49 PM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
Interesting info about the 15%! I’m even more interested about the comment above. How have you come to learn this? My dealer here in Sweden recommended trickle charging to me when I parked my car for 5 months earlier this year. So far, I don’t think I’ve ruined my dc to dc charger, as it’s still behaving like it’s supposed to. Furthermore, they have trickle chargers on all their EQ cars in the showroom.
Old Dec 5, 2024 | 06:12 PM
hlothery's Avatar
Veteran: Army
Each time (twice) I have taken my 22 EQS in for service, they have put the 12V battery on a charger while in the shop.
Old Dec 5, 2024 | 06:19 PM
EQEBlue's Avatar
EQE 350 4matic
The way DC DC converter degrades is in terms of efficiency. So it will use more power to boost the 12V, wasting the rest as heat. I've been able to nail the 15% HV SoC value from running tests; my old job was designing and testing EV hardware platforms. The original idea was to have on-ground power like with aircraft, but it looks like MB decided not to commit to doing it down the trickle charger route.
Old Dec 6, 2024 | 11:48 AM
Isn't obvious for the first point? Discharging the HV battery too much (taking into account that the car may be parked for a long time after charging the LV battery) is more critical than letting the LV battery run flat. Most often this would not kill the LV battery but even if it did, much cheaper and easier to swap the LV battery than the HV battery.
I don't get your point on the 12 V chargers. As mentioned above, a standard procedure to hook a high power 12 V charger at service to take care of the power consumption when the diagnosis tool is used etc. Do you mean the workshop could use a HV charger instead? Perhaps so but they don't have that for all cars being serviced and I believe the safety rules do not allow that either.
Old Dec 9, 2024 | 09:10 PM
cdcted's Avatar
1990 420sel, 2002 500sl silver arrow 2019 bmwi3 2023 eqs580 pinnacle
Intersted in how to attach a trickle charger without entering the forbiden hood area on my eqs?
Old Dec 10, 2024 | 04:34 AM
ScottC2's Avatar
On my EQE SUV, you can't. You need to enter the forbidden zone. I presume it's the same for the EQS's. I've done it in order to use a trickle charger -- and it's no big deal. Just a PITA.
Don't even think about using one of those trickle chargers that come with a plug for a 12v socket. For starters, the car needs to be powered on for that circuit to close.
